Content Count
86 -
Joined
Last visited
Everything posted by musiclinkav
New Arrival for 2011@ Musiclink Introducing the world acclaimed ROGERS LS3-5A Monitor Speaker - 65th Anniversary Edition. Intro Price@ $1830.00/pair. System Type : Two-way infinite baffle (closed box) Frequency Response : 70Hz - 20kHz +/- 3dB Sensitivity : 83dB for 2.83V @1m Bass / Midrange Driver : 138mm Tweeter : 19mm Crossover : Frequency 3kHz. Bi-wireable Sensitivity : 83dB for 2.83V @1m Nominal Impedance : 11 ohm Recommended Amplifier Range : 30-80 watt Cabinet : 10mm Birch multi-ply. Critically damped Grille : Black Tygan Finish : Red Cherry Available Now@ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 62911106 BUSINESS HOURS: MON-SAT: 12.30-8PM DAILY. SUN & PUBLIC HOLIDAY: CLOSE.
USUAL PRICE@ $575.00/PAIR. PROMO PRICE@ $499.00/PAIR. Free Audioplus PCOCC speaker Cable valued@ $199.00/2.5m pair with every purchase. 2011 New Arrival@ Musiclink! Introducing the Award Winning Mordaunt Short Aviano 1XR. AWARDED a What HI-FI 5 STAR for a bolder and more stable sound than the original; stronger dynamics; works well with a wide range of music. Change of crossover design has turned a fine speaker into an excellent one. The 1 XR is one of the stars at this price level. Model: Aviano One XR Bookshelf Exciting things can happen when you take your best selling, world award winning model with the mission to make it even better! Continuous research is at the very heart of everything we believe in and Mordaunt-Short’s new Aviano 1XR is the perfect example of our passion for the ultimate performance. By creating a new premium crossover design and completely retuning our best-selling Aviano range, the Aviano 1XR is, without doubt, one of the most sophisticated and competent standmount speakers ever created. The Aviano 1 XR is a true powerhouse which delivers entertainment by the bucket-load yet consumes minimal living space. Its potent 5¼" driver communicates with incredible authority and integrates flawlessly with Mordaunt-Short’s proprietary aluminium dome tweeter for a highly detailed, smooth and room-enveloping soundstage. Aviano 1 XR’s all-new second-order crossover brings about a number of technical benefits, the result of which makes our budget hero an more thrilling listen than all its peers... How’s this possible? Well firstly, the crossover rolls-off the driver units faster which means less overlap between the midrange and tweeter thus improving off-axis response. This benefit is most apparent in non-optimised listening environments – typical of most people’s homes – meaning better balance and precision whether listening intently to the intricacies of a symphony orchestra or being entertained by something altogether more raucous. Another distinct advantage of the new Aviano XR’s crossover is its ability to carefully limit lower frequencies which reach the tweeter. This is the key to even greater power handling and lower distortion which allows Aviano 1 XR to play louder and more accurately than ever before. Critically the results of our latest project are not just limited to the acoustics lab but are real world benefits which add focus, coherence and accuracy to the music you love. So experiencing the new Aviano 1XR is the only way to truly appreciate what’s possible from Mordaunt-Short’s new compact hero. SPECIFICATIONS: Aviano 1XR standmount speaker Sensitivity 89dB Frequency response 55Hz - 22kHz Impedance 8 ohm compatible Drive units Tweeter: 1 x 25mm (1”) aluminium dome tweeter Woofer: 1 x 130mm (5.25”) aluminium CPC™ woofer Crossover 2nd order Recommended amplifier power 15-100 Watts Dimensions (h x w x d) 275 x 179 x 267mm (11 x 7.2 x 10.7") Weight 5kg (11lbs) Ported 1 rear Finishes Black Reviews & Awards http://www.mordauntshort.com/assets/docume...iano1XR_web.pdf Need We Say More? On Demo Now @ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 Tel: 62911106 Mon-Sat: 12.30-8pm daily Sun: Closed Cash & NETS accepted! PRICE INDICATED EXCLUDE 7% GST
New arrival for 2011! Introducing the new Isotek Syncro active powercord. Usual Price@ $1850.00/2m each. Intro Promo Price@ $1599.00/2m each. Free Blue Horizon Clean-it Contact Cleaner/Enhancer valued@ $50.00/bottle with every purchase! What is Syncro? In simple terms, Syncro is IsoTek’s most advanced mains cable – but it’s also so much more. The cable incorporates innovative electronics, housed in an anti-resonant aluminium case positioned part way down its length. This unique circuitry is designed to synchronise the mains supply in order to promote a perfectly symmetrical sine wave, delivering significant sonic improvements when used with any hi-fi separates system. Syncro is not a mains conditioner or filter in the accepted sense. It can be used on its own to power a single hi-fi component, and will bring significant improvements if used in this way. However, it is primarily designed as a ‘pre-filter’ device – for best results, plug the Syncro into a wall socket and use it to power an IsoTek or any mains conditioning unit. Thus, Syncro takes the mains electricity supply and realigns its waveform, prior to filtration of contaminants (RFI/EMI etc.) by the conditioning unit, which then feeds each hi-fi component – thus improving the performance of every link in the audio chain. The cable itself is identical to IsoTek’s top-of-the-line Extreme power cable. It features heavy-gauge, triple-screened, 20Amp oxygen-free copper conductors suitable for high-current demands, coupled to top-quality connectors at either end. Both the mains plug and the IEC connector are precision machined from high-purity copper, heavily plated in 24ct gold, deep cryogenically treated and then demagnetised. The main bodies are made of injection-moulded polycarbonate, for ease of handling, durability and long-term reliability, while the IEC plug’s precision injection-moulded front assembly ensures precise mating with power sockets. How Does Syncro Improve Audio Performance? As we fill our homes with an ever-increasing number of electrical devices, we further degrade the mains supply, interfering with its quality and consistency. Audio equipment uses electricity to generate signals, amplified by more electricity to drive a pair of loudspeakers; the quality of the electricity that feeds an audio system has a direct impact on the resulting quality of sound. IsoTek’s extensive range of mains conditioning components improves the quality of the mains supply significantly, filtering out contaminants like RFI and EMI, and ensuring each component in the audio chain receives pure and consistent power in line with its specific requirements. However, there is a further issue with the electricity supply in our homes that has existed for years, without a truly effective commercial solution. The problem in question is sometimes referred to as ‘DC on the mains’. In terms of audio equipment, it is often signified by a buzzing sound emitted by a transformer in a power amplifier. Of course, this buzz is extremely distracting to the listener, and hardly in keeping with the concept of high-resolution audio. In addition, the mechanical vibration within the power transformer, created by core saturation, results in microphony in the internal components, leading to further degradation of sound quality. These issues have nothing to do with the quality of the audio equipment used. In fact, some of the best amps available are the most seriously affected. The problem is a symptom of the poor state of mains electricity available in most homes, affecting not only amplifiers but source components, too. Most of the DC-related issues suffered by audio systems are brought into being by the electrical devices we own, directly ‘rectifying’ the mains from AC to DC (where a diode is used in series to allow either the positive or negative cycle of the mains sine wave to pass). The use of switch-mode power supplies exacerbates the problem, introducing measurable mains distortion. These devices create a lack of symmetry in the mains sine wave where it is displaced from the zero voltage line, leading to the aforementioned hum that’s often noticeable from power amplifiers, as the DC voltage saturates the core of the transformers with DC current. This, in turn, generates unwanted mechanical vibration, resulting in audible noise and microphony, and increased power consumption and heat. To give an example, if a sine wave reaches a peak of 326 Volts in the positive direction, it should also reach 326 volts in the negative direction to have perfect symmetry. This actually describes the reality of a 230 Volt AC wave form; the 230 Volts describes the heating effect of a sign wave whose peak is 326 Volts. If one peak reaches 327 Volts and the other 325 Volts, there is lack of symmetry. Although common sense suggests that such small variations should have no effect, in reality they create serious problems for audio systems; even tiny changes registering no more than a few millivolts create significant operational difficulties for amplifiers. Inadequate remedies of the past… Historically, IsoTek advocated the use of huge isolating transformers to improve the cleanliness of the electricity supply (the company has since developed more advanced components for use in its power conditioners). A by-product of this technology helped to compensate for DC elements on the mains. However, this merely shifted the problem away from the audio equipment to the isolating transformer itself; audible mechanical hum may have been removed from the transformer in the power amp, but the isolating transformer would hum instead. Ironically, in order to try to reduce dynamic loss in the amplifier created by the insertion of the isolation transformer, larger and larger devices were needed. However, the bigger the transformer, the louder the mechanical noise; the problem was never truly solved, merely shifted and often made worse. A new solution: IsoTek Syncro… IsoTek’s research has led to the conclusion that mains electricity should be a pure sine wave of either 50Hz or 60Hz of correct voltage and good symmetry about the zero volt line, in order to power audio equipment with maximum effectiveness. The Syncro is solely concerned with creating zero-volt symmetry, but also forms a vital part of IsoTek’s product range in working towards the ideal state of a pure sine wave. In designing the Synchro, the challenge for IsoTek was to offer a universal solution to remove the unwanted and damaging DC component from the mains supply, whilst allowing the maximum possible current to pass. IsoTek’s latest engineering solution and DC-blocking technology developed for the Syncro is in many ways superior in performance to a massive 12,000VA isolating transformer, delivering greater dynamic ability. (Incidentally, a 12,000VA isolating transformer is twice the size of IsoTek’s largest historic product.) Syncro’s sonic effect… As well as removing any audible hum from a power amp, Syncro’s synchronising effect results in greater bass depth, improved timing, a reduction in the noise floor and a more palpable sound overall. Furthermore, these improvements don’t come at the expense of dynamic ability; in fact, in some cases dynamics are considerably improved. This can be explained by the fact that at zero volume, many power amplifiers consume less power in idle. The Syncro helps the amplifier to consume less electricity, freeing up power for dynamic transients. A simple analogy is a car that is free running, as opposed to having the brakes slightly engaged. <Features> - Stops transformer buzz, a common problem referred to as DC on the mains. - Can be used on all high quality HIFI separates including mains filters. - Improves sound quality. - High quality 24k gold connectors. - Advance power cord with active shielding. - Award winning design team Reviews & Awards: http://www.isoteksystems.com/auto_images/review_pdfs/31.pdf http://www.isoteksystems.com/auto_images/review_pdfs/32.pdf Available now@ MUSICLINK AV DISTRIBUTION 100 BEACH #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 65-62911106 MON-SAT: 12.30-8PM daily. Sun & Public Holiday: Closed.
New @ Musiclink Announcing the arrival of LAT INTERNATIONAL's new USB cable. Designed, Engineered & Manufactured in the USA. Usual Price@ $145.00/1.0m each. Introductory Promo Price@ $109.00/1.0m each. A High End USB 2 Cable for Maximum Fidelity Digital Signal Transfer If you store your music on a computer, our USB 2 Signature will give you the best streaming audio transfer possible. Some select customers who auditioned pre-production prototypes told us the fidelity they experienced far exceeds that of a number of other USB cables to which they compared. Low jitter along with better smoothness, detail, clarity, focus and powerful controlled bass is what you will hear. This is a must where high resolution data is involved whether it be in consumer or professional use. This cable is capable of superb sound reproduction, especially with high resolution recordings; and as with any system component, you need a well-engineered and well built USB cable to achieve it. We developed this high end cable to take advantage of the potential that exists to achieve superb reproduction with a USB DAC. Consistent with our continuing design philosophy, our Silverfuse conductors are also used in this cable. The conductors are the largest in the industry at 22 gauge to provide for maximum conductivity. The wires are insulated with Teflon, the best insulation available. Competing cable companies use PE (Polyethylene). Polyethylene is readily available and is used commercially for television wire and other commodity coaxial cables. It is inexpensive and far inferior to much more costly Teflon; especially ours which we modify to our specifications. Sensitive signals transfer with no interferences ensured by ferrite filters and multiple layers of shielding that provide 220 percent of shield coverage. Features: Our proprietary Silverfuse metal conductors Large 22 gauge internal conductors – largest in the industry to ensure maximum clarity in signal transfer. All conductors are Teflon insulated Cable interior filled with Polypropylene fibers for vibration damping and antistatic protection. We have not seen this important provision on any other competing USB 2 cable. EXPLANATION OF OUR PROPRIETARY SILVERFUSE CONDUCTOR MATERIAL: Silverfuse is a near alloy of silver and copper. The copper used in this process is Single Crystal Continuous Cast Copper. It has unique physical and chemical properties, such as considerably longer granules with absolute absence of gaseous impurities such as oxygen, carbon, hydrogen and nitrogen. It is free from impurities (up to 99.99998% pure copper). It is far better than continuous cast Oxygen Free High Conductivity wire (OFHC). IT IS NOT SILVER PLATED. Silver plating causes a dioding effect when signal is passed through resulting in brightness and distortion. Because silver plating has a bad reputation, some manufacturers try to disguise the fact by calling it silver coated, silver clad or silver/copper hybrid. But they are all silver plated. Our Silverfuse process starts with Single Crystal Continuous Cast Copper wire with a diameter that is slightly larger than the required size. It is then pulled through a trough of molten silver. The wire with a silver deposit is then forced through a compacting process where it is subject to tremendous pressure. The silver and the copper are fused together into a near alloy. The compacting fusion also reduces the wire diameter to the desired size. No dioding subsequently occurs with this process. The result provides for the benefits of silver; which are excellent definition and clarity, with the high purity copper benefits of warmth and mellowness. (Incidentally, pure silver wire also causes brightness) Available now@ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER TEL: 65-62911106 BUSINESS HOURS: MON-SAT: 12.30-8PM SUN & PUBLIC HOLIDAY: CLOSE
Its possible now with the HRT iStreamer DAC.
2011 New Arrival@ Musiclink! Usual Price@ $865.00/each. Intro Price@ $699.00/each. Free Esoteric Audio USA silver interconnect valued@$185.00/1m pair for the first 20 customers who purchase or reserve with deposit the ADL-GT-40 DAC. To further sweeten the perks, we will include 1 piece of new Audioplus Xtreme USB cable(2m) valued@ $59.00/each with every purchase! Hurry While Stocks Last! Furutech Introduces the 24/96 GT40 USB DAC with Phono Stage--The GT40 is finally here, built for enthusiasts with growing music collections on their computer hard drives. It’s a high performance 24-bits/96kHz USB DAC that’s amazingly affordable at only $480 in the USA. Looking to convert your LPs or other analog sources to digital? The GT40 will take you to the podium with every album you archive. The seriously-shielded audiophile-grade GT40 features a low-latency USB 2.0 audio driver that plays and records at 96kHz. A likely first for this category, the GT40 includes a built-in low-noise MM/MC phono preamp! Record your favorite vinyl to hard disk via the USB output. The ADL GT40 features L/R analog outputs, and switchable line or phono inputs with a vivid, captivating sound that is simply unheard of in this category. The ADL GT40 brings Furutech’s signature sound--smooth, detailed clarity--to desktop systems, especially with high resolution 24-bits/96kHz files, but even 16-bit/44.1kHz files sound impeccable and very musical. Features: High performance 96KHz/24bit USB DAC and ADC IC chip Enjoy audio in high resolution at 96KHz/24-bits surpassing conventional 44.1KHz/16-bit standards Incorporates the most trusted driver in professional audio for 96kHz recording and playback External power supply Headphone Amplifier: It contains a high performance headphone amplifier with ample drive for good quality headphones Analog-to-Digital Converter: The GT40 sports a high-performance ADC IC chip for high resolution recordings via analog inputs. Input can be used for phono, AM/FM radio, or other analog signals. Phono Preamplifier: A first for this class, the GT40 features a phono equalizer for recording your precious LPs. Switch between moving magnet (MM), moving coil (MC), or defeat the preamp and use the input for line level audio signals Highest Quality Parts: The GT40 features a high quality amplifier design and parts, including audio grade condensers supporting its high performance analog circuit High End Audio Grade Connections: The GT40 is equipped with gold-plated Teflon-insulated RCA jacks with an extremely high quality aluminum chassis and machined volume knob The GT40 Gets You to the Winner’s Circle! Reviews & Awards: "The Alpha Design Labs GT40 USB DAC with Phono Stage (by Furutech) is a masterful little device with a long list of features and strengths - all at a price of just US$495. Given its build quality and performance, this is one of the best bargains I’ve come across in a long time in the audio world." ----- Neil Underwood, http://www.furutech.com/a2008/reviewc.asp?r1_no=26&r2_no=499 http://www.furutech.com/a2008/reviewc.asp?r1_no=85&r2_no=497 http://www.furutech.com/a2008/reviewc.asp?r1_no=85&r2_no=487 http://www.furutech.com/a2008/reviewc.asp?r1_no=52&r2_no=486 http://www.furutech.com/a2008/reviewc.asp?r1_no=5&r2_no=477 http://www.furutech.com/a2008/reviewc.asp?r1_no=90&r2_no=475 http://www.furutech.com/a2008/reviewc.asp?r1_no=87&r2_no=468 http://www.avguide.com/article/alpha-desig...analog-recorder Available now@ MUSICLINK AV DISTRIBUTION 100 BEACH #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 65-62911106 MON-SAT: 12.30-8PM daily. Sun & Public Holiday: Close
HRT TECHNOLOGIES USA We are currently SOLD OUT for the hot selling iStreamer. New Shipment arriving in February 2011. As demand is high and supply is low, please kindly visit us to reserve a unit soon! Deposit required! Model: 2011 iStreamer - In Stock! USUAL PRICE@ $360.00/EACH. PROMO PRICE@ $299.00/EACH To further sweeten the deal, we are offering a pair of Esoteric Audio PCOCC interconnect worth $85.00/1m pair FREE to the first 50 customers to purchase the iStreamer from us The iStreamer is a high performance audio interface that allows an Apple iPad™, iPhone® or iPod® and a home entertainment system to become perfect partners. With an iStreamer connected, you can enjoy true CD quality sound with the convenience of having all your music on one device. Simply plug your iPad, iPhone or iPod into the iStreamer; plug the iStreamer into its included power supply and your home entertainment system. From the iPod 'App' on iPad or iPhone or directly on iPod simply push 'play' and enjoy unmatched sound quality and convenience. With its ultra high performance circuitry and host mode of operation (eliminating interface jitter) , the iStreamer renders the CD player and CD library obsolete. For the first time, you can enjoy a level of sound quality never before possible from a portable audio device. The iStreamer provides full support for applications designed to run on an iPad, iPhone or iPod. The iStreamer allows you to connect to a home entertainment, television or stereo system to listen in high quality to Internet radio, streaming music and movies from providers such as Rhapsody™, Napster™, Pandora™, Netflix™ and other online services. Specifications Available now@ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 65-62911106 BUSINESS HOURS: MON-SAT: 12.30-8PM daily. SUN & PUBLIC HOLIDAY: CLOSE
HISAGO JAPAN [Hisago Christmas Promo@ Musiclink We will be conducting a Deal of the Century Promo-BUY 1 pair GET 1 pair FREE for the following models of Hisago interconnects. Hurry this is a once in a life time Factory offer NOT to be missed. All models while stocks last! Models currently on Promo are: Interconnects-BUDGET 1. HD-23080 OFC* 2. HD-30870 OFC* Interconnects-Affordable 3. HD-21870 OFC 4. HD-11890 OFC 5. HD-13760 OFC 6. HD-13770 OFC Interconnects-Mid Affordable 7. HD-22800 PCOCC-Most popular model for car audio application! Available in 1m, 2m, 3m pair. 8. HD-13780 PCOCC+ 9. HD-13790 PCOCC+ Interconnects-MID-High Affordable 10. HD-13350 6NINES 11. HD-22830 6NINES Interconnects-High Affordable 12. HD-13800 7NINES 13. HD-13810 7NINES Available now@ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 62911106 BUSINESS HOURS: MON-SAT: 12.30-8PM daily. SUN & PUBLIC HOLIDAY: CLOSE
HRT TECHNOLOGIES USA NEW ARRIVAL FOR 2010! Model: Streamer 2-SOLD OUT! STOCKS ARRIVING SOON! CALL US. USUAL PRICE@ $280.00/EACH. PROMO PRICE@ $229.00/EACH HRT Music Streamer II- Our Best Little USB DAC Gets Even Better! Now 24/96 Capable and Asynchronous USB Compatible! 2009 The Absolute Sound Golden Ear Award Winner! The Music Streamer turns your computer into a high-resolution audio source. A high performance USB DAC, the Music Streamer connects to your computer's USB output and streams audio from your computer directly to your audio system. Whether you use audio files already on your computer, streamed audio from the tens of thousands of online radio sources, play computer games or watch movies, the possibilities are endless. Simply connect a USB cable to the Music Streamer's input and use a pair of analog cables to connect the Music Streamer's output to your audio system and the hard part is over! You'll need a B-Bus USB Cable to connect the Music Streamer to your system, find one here. The Music Streamer II features a revised and improved audio DAC along with 24/96kHz compatibility and Asynchronous USB. All this in a compact, solid lightweight aluminum chassis. With its unique topology, the Music Streamer II provides a completely isolated path between the computer and audio system. No more audio contamination by the computer; your music will always sound its best! There are no external power supplies to worry about, the Music Streamer II derives its power directly from the USB bus, completely regenerating the power for its internal circuitry using a sophisticated and extremely efficient power supply. The Music Streamer II provides full compatibility with iTunes and Windows Media Player as well as a large number of other programs. The Music Streamer II is compatible with 24Bit/96kHz tracks! Stream music, computer game audio, even movie soundtracks directly from your computer to your home entertainment system, with a level of quality never before possible. You can also use Music Streamer II to listen to internet radio or other music subscription services such as Rhapsody, Pandora or Napster in high quality through your home stereo system, television or home theater system. Specifications: Electrical Full Scale output 2.25 Volts RMS Frequency Response (20 Hz/20 kHz) 0 dB/ - .5 dB Noise Floor (DC to 30 kHz) 26 uV RMS S/N Ratio (DC to 30 kHz) 98 dB THD+N (1 kHz FS 44.1 kS/s) 0.010% USB to Audio output isolation > 20M Ohm Interface Data Rate up to 96 kB/s Bit Depth up to 24 bit Transfer Protocol asynchronous USB type 1.1 or above Power Requirements (USB bus) 200 mA Dimensions (LWH) 4.1” x 2.1” x 1.2” Reviews & Awards:“What if I told you that you could have a cheap USB DAC that delivers true high-end sound? If you don’t believe me, try comparing it with your favorite high-priced USB DAC. After all, at this price you can afford to be daring!” – Steven Stone, Golden Ear Award Issue, The Absolute Sound, June/July 2009 Model: Streamer 2+-STOCKS AVAILABLE USUAL PRICE@ $630.00/EACH. PROMO PRICE@ $479.00/EACH 24/96 Capable and Asynchronous USB Compatible! The Music Streamer II+ is an amazing USB DAC specifically designed to extract the best quality, high-resolution audio from any computer. Using the Music Streamer II+ couldn't be easier, simply connect the Music Streamer II+ to your computer via a USB cable and the installation happens instantly. Connect the Music Streamer II+ to your system with a pair of RCA interconnects and you're ready to stream music. You'll need a B-Bus USB Cable to connect the Music Streamer II+ to your system, find one here. The Music Streamer II+ features a revised and improved audio DAC along with 24/96kHz compatibility and Asynchronous USB. A substantial upgrade from its baby brother, the Music Streamer II+ has a better DAC and more powerful high-current analog output section. This translates to better imaging, a broader and richer tonal pallette and much better low-frequency performance. All this in a compact, solid lightweight aluminum chassis. With its unique topology, the Music Streamer II+ provides a completely isolated path between the computer and audio system. No more audio contamination by the computer; your music will always sound its best! There are no external power supplies to worry about, the Music Streamer II+ derives its power directly from the USB bus, completely regenerating the power for its internal circuitry using a sophisticated and extremely efficient power supply. The Music Streamer+ provides full support for applications such as iTunes and Windows Media Player direct to your audio system, with a level of quality never before possible. You can also use the Music Streamer+ to listen to internet radio or other free and music subscription services such as Pandora, Rhapsody or Napster, with better sound than you’ve ever heard before. High Resolution Technology’s Music Streamer+: the product for tomorrow… available today! Our highest recommendation! “The MusicStreamer+ really does make a significant difference to sound quality. It’s completely seamless, with a whisper-quiet background that will shock you. Sounds are easily delineated from one another. You plug your laptop into the MusicStreamer+, plug the Streamer into your system and play music – your first comment uttered will be ‘WOW!’” - Alan Sircom, HiFi+, Issue 64 Specifications: Electrical Full Scale output 2.25 Volts RMS Frequency Response (20 Hz/20 kHz) 0 dB/ -1.4 dB Noise Floor (DC to 30 kHz) 20 uV RMS S/N Ratio (DC to 30 kHz) 101 dB THD+N (1 kHz FS 44.1 kB/s) 0.008% USB to Audio output isolation > 20M Ohm Interface Data Rate up to 96 kS/s Bit Depth up to 24 bit Transfer Protocol asynchronous USB type 1.1 or above Power Requirements (USB buss) 350 mA Dimensions (LWH):5.1” x 2.1” x 1.2” Model: Streamer PRO-available USUAL PRICE@ $899.00/EACH. PROMO PRICE@ $699.00/EACH LATEST NEWS: AWARDED HIFI-NEWS EDITOR'S CHOICE DEC 2010. The Fully Balanced HRT Music Streamer PRO USB DAC is One of the Best Sounding Available! The HRT Music Streamer PRO is a high performance USB DAC music interface that allows your computer and your high-end audio system to become perfect partners. With its unique topology the Music Streamer PRO provides a completely isolated path between the computer and the audio system. No more contamination of the analog signal by the computer environment; no matter the situation, the results will always be their best. The fully-balanced Music Streamer Pro USB DAC is one of the best USB DACs we've heard! You'll need a B-Bus USB Cable to connect the Music Streamer II to your system, find one here. There are no external power supplies to worry about because the Music Streamer Pro derives its power from the USB bus while completely regenerating power for all its internal needs using a sophisticated set of proprietary circuits. Operation is simple: just plug the Music Streamer Pro into any USB port on your host computer and the Music Streamer Pro will install itself and be ready for use in a matter of moments. Connect the other end into any Balanced Analog Input and you are ready to transfer extremely high quality computer based audio. Full support for both adaptive and asynchronous transfer modes assures that jitter performance exceeds that of conventionally connected (bi-phase) converters. The Music Streamer PRO provides full support for any application via the native audio path on both Windows and Macintosh operating systems. The Music Streamer PRO is the perfect USB DAC offering portability, noise isolation and ultra high performance in a single mission product. If you expect nothing but the best sound from your computer based music files, then the Music Streamer Pro is an essential component in your digital workplace. NOTE: The Music Streamer PRO requires a special mini-XLR fully balanced interconnect. At Musiclink we carry a range of interconnects terminated with the mini-XLR. Specifications: Electrical Full Scale Output: 4.5 Volts RMS (TiniQ XLR) Output Impedance: 200Ω (balanced) Frequency Response: (20 Hz / 20 kHz) * 0dB / -.6dB Noise Floor (DC to 30 kHz) 9 μV RMS Noise Floor (A-weighted) 8 μV RMS S/N Ratio (DC to 30 kHz) 114 dB S/N Ratio (A-weighted) 115 dB THD+N (1 kHz FS) .004% USB to Audio output isolation: > 20MΩ * - .3 dB @ .48 FS for any sample rate up to 96k Interface Data Rate: up to 96 kbs Bit Depth: up to 24 bit USB: Type 1.1 Power Requirements: 350 mA (USB Buss) Dimensions (WDH) 2.1”x5.6"x1.2" Reviews & Awards: http://www.audioenz.co.nz/2009/musicstreamer.shtml http://www.positive-feedback.com/Issue43/satori_usb_dacs.htm http://www.soundstage.com/digitaldomain/200905.html http://www.6moons.com/audioreviews/hrt2/pro.html Remarks: Remember to bring your lab-top to try it! Available now@ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 65-62911106 BUSINESS HOURS: Mon-Sat:12.30-8pm daily. Sun: Closed
ETI-EICHMANN 10 AWG EXPRESS TELLURIUM COPPER POWERCORD PROMO@ MUSICLINK Thank you for your support! We are now SOLD OUT for ETI's awesome Tellurium Copper Powercord! Look out for our next shipment! Latest Hot Hot deal! Buy 2 meters of the Express Tellurium Copper Power Cord and get 1 piece of Ambiance PCOCC+ IEC worth $38.00/each absolutely free. All you need is to purchase another USA plug to compliment the IEC and than you are all set! Try it and be blown away! USUAL PRICE@ $48.00/M. PROMO PRICE@ $38.00/M (TELLURIUM COPPER). PROMO PERIOD: 1 OCT- WHILE STOCKS LAST! User comments: Tried 2m length on my system and was shock by the superb resolution, improved depth and definition, superb imaging and increase in details. Put it simply mind blowing! BEST OF ALL REALLY AFFORDABLE!!!!---MR YONG. WIKIPEDIA REFERENCE: "With an abundance in the Earth's crust comparable to that of platinum, tellurium is one of the rarest stable solid elements in the Earth's crust. The extreme rarity of tellurium in the Earth's crust is not a reflection of its cosmic abundance, which is in fact greater than that of rubidium, even though rubidium is ten thousand times more abundant in the Earth's crust. The extraordinarily low abundance of tellurium on Earth is rather thought to be due to conditions in the Earth's formation, when the stable form of certain elements, in the absence of oxygen and water, was controlled by the reductive power of free hydrogen. " Express Wire: The Express wires are a true evolution. We learned from the success and critical acclaim of our first foray into high performance audio cables. We've added practicality and flexibility through multi-core wires. Enhancing the sonic qualities to even greater heights. Express wires are unique. The product of more ingenuity and hours of listening comparisons. Around the purest of copper conductors we utilize special materials to minimize inductance, capacitance and resistance. All gauges and densities are formulated around the omnipresent S/G S/G Ratio. The Express range features three designs that are optimized for their respective applications. S/G Ratio: The Golden Ratio for signal transmission is ETI's patented Signal/Ground or S/G Ratio. Formulated from listening experience and physics fundamentals, the S/G Ratio is applied to many aspects of the cables' conductivity to optimize the electron flow. Key to its implementation are the deliberate differences, physical and electrical, between a cable's signal and ground conductors. Most famously applied to the solid copper cores of cables, research into the S/G Ratio was extended and is now applied to the unique wires used in the Express Cu and Express H range. When implemented successfully audio system performance is appreciably better. Increased detail and smooth reproduction deliver a high end presentation that good music deserves. Hybrid Theory: The Hybrid Theory is the metallurgical application of the S/G Ratio. Hybrid connectors are the new performance standard for ETI cables. Our development of high performance audio connectors from the best conductor metals available concluded that Copper connectors are a superb standard for musical enjoyment and Silver is beneficial only in certain applications. Irresistibly superior experimental results were achieved when researching a collaboration between Copper and Silver, using the differential conductivity to reinforce the S/G Ratio effect of the wiring. ETI's Express Hb are completely optimized with Hybrid connectors. ETI's Values: ETI's traditional values are preserved with the new range of Express Cables. Innovation Completely new and unique cables, Hybrid Technology and the evolution of the S/G Ratio. Metallurgy Continued commitment to high conductivity metals- Silver and Copper- the multi-stranded wires are made from Copper and our commitment to continual development has created the Hybrid Theory. Geometry The new Express wire configurations are calculated using the fundamentals of the S/G Ratio. Low Mass Multi-stranded copper and lightweight cable materials have ensured that electron flow is efficient and undiminished and the cables can be physically handled and shaped for any circumstance. Please also visit www.musiclinkav.com for other mind blowing accessories and parts. Available now@ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 62911106 BUSINESS HOURS: MON-SAT: 12.30-8PM DAILY. SUN: CLOSED.
CI AUDIO USA NEW!NEW!NEW! MODEL: VDC 9.0 PSU PRICE @ $502.00/EACH. PROMO PRICE@ $399.00/each. Our new VDC•9.0 is the perfect upgrade for two of today's most popular music playback methods. The Slim Devices/Logitech Squeezebox Duet, and the Wadia 170 iTransport. When used with either device, the upgrade eliminates noise caused by the standard switching supply, which can contaminate the internal digital and analog circuits. The design utilizes a low noise/high current transformer, with discrete Schottky diode bridge rectifier, AC line filter, precision voltage regulator circuit, and 13,600uF of filter capacitance. Available in 120 or 240v input. AC input and DC output cables included. Specify cable type when ordering. Specification AC Input Voltage: 120/240VAC Output Voltage: 9V DC @ 2.5 Amps Accessories: IEC Type AC Cable, DC output Cable Dimensions: 4.40"w x 2.65"h x 4.40"d Warranty: 1 Year Parts & Labo Audition now @ Musiclink AV Distribution 100 Beach Road, #02-46-49 Shaw Tower Singapore 189702 tel: 65-62911106 Mon-Sat: 12.30-8pm daily. Sun: Closed
CI AUDIO USA NEW!NEW!NEW! MODEL: VDC SB PSU PRICE @ $470.00/EACH. PROMO PRICE@ $399.00/each. VDC•SB High Current Squeezebox™ & Onkyo ND-S1 Power Supply Take your Squeezebox Touch,Classic SB3 or Onkyo ND-S1 Ipod transport to the next level. The VDC•SB eliminates switching supply noise and feeds precisely regulated power to your device. Features Our new VDC•SB is the perfect upgrade for your Logitech Squeezebox, Touch, Classic SB3 or Onkyo ND-S1 Idock transport. The upgrade eliminates noise caused by the standard switching supply, which can contaminate the internal digital and analog circuits. The design is based around a 4A continuous rated transformer, discrete Schottky diode bridge rectifier, AC line filter, precision voltage regulator circuit, and 20,000uF of filter capacitance. VDC•SB, Squeezebox, and a quality external DAC system such as VDA•2/VAC•1 creates a wireless digital audio source that competes with some of the worlds most expensive CD players! Available in 120 or 240v input. AC input and DC output cables included. Reviews “With the addition of the CIAudio power supply, the soundstage tightened up and images became more stable and defined. It was a nice change. I’d say it was subtle but noticeable.” - mcullinan, AudioCircle forum member <Specifications> AC Input Voltage120/240VAC Output Voltage5V DC @ 2.2 Amps AccessoriesIEC Type AC Cable, DC output Cable Dimensions4.40"w x 2.65"h x 4.40"d Warranty1 Year Parts & Labor Audition now @ Musiclink AV Distribution 100 Beach Road, #02-46-49 Shaw Tower Singapore 189702 tel: 65-62911106 Mon-Sat: 12.30-8pm daily. Sun: Closed
NEW ARRIVAL FOR 2010!!! PRICE: Call for Pricing! FURUTECH's ultimate receptacle. No other receptacle in the market is built like the GTX! Check it out today! Awesome performance! Model: GTX-D GOLD OR RHODIUM-In Stock Available in Single or Duplex NEW ITEM! Furutech has just launched their new groundbreaking GTX-D series PURE COPPER receptacles!!! The new GTX series is the first AC receptacle I'm aware of that use PURE copper contacts (not brass or bronze). Furutech worked for years to solve the springiness/hardness issue that previously prevented the practical use of pure copper, and the way they did this was ingenious! Another BIG benefit to the new Furutech GTX series is the fact that it won't mar the finish of expensive platings on your male AC plugs. The superior conductivity of pure copper vs. any brass or copper alloy is evident in the huge micro and macro dynamic contrasts, and sweet, extended highs. Grip is excellent, and I consider the Furutech GTX series to be THE best receptacle I've heard. Choose rhodium if you prefer a more up-front presentation, or gold, if you prefer a slightly warmer, more laid-back presentation. Check it out today @ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 62911106 MON-SAT: 12.30-8PM SUN & PUBLIC HOLIDAY: CLOSE
LAT INTERNATIONAL USUAL PRICE@ $38.00/2.4oz bottle. PROMO PRICE@ $29.00/2.4oz bottle. Green Line CD Performance Enhancement With the apparent demise of Audio Prism, their popular and effective Stop Light product is no longer being produced. So all of you fans of this product, and there are many, need not fret. We have been and are still producing our equivalent of this product that we have named Green Line. This is a product that is applied on the edges of a CD disk. It provides very significant improvement in the sound quality of the disk - but why? The green material absorbs stray and refracted rays of the laser beam that after penetration into the disk, scatter and bounce back off of the inside edge of the disk causing smearing of the data. We have found that the effectiveness of the treatment is related to how closely the wave length of this green material is to the complementary wave length of the 790 NM laser beam. A simpler example is the relationship of the wave length of a color of blue that is the exact complement to a wave length of a color of yellow. The blue and yellow will cancel each other out and what remains is black. Black is the absence of color. In the case of this treatment, the stray bits of the laser beam that are bouncing around in the interior of the disk are canceled out; eliminated. Our Green Line is formulated to match exactly the required complementary wave length of the laser beam. Although originally developed for audio CDs, some users have reported back seeing video inprovements when used on DVD, HD-DVD, and Blu-Ray Available now@ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 62911106 BUSINESS HOURS: MON-SAT, 12.30-8PM daily. SUN & PUBLIC HOLIDAY: CLOSE.
LAT INTERNATIONAL USUAL PRICE@ $88.00/SET OF 4. PROMO PRICE@ $69.00/SET OF 4. New shipment has arrived for VIBRAKILLER. Vibra-Killers Anti-Vibration feet Several Companies are marketing vibration absorption feet made of sorbothane or similar material. We have replaced our sorbothane feet with ones composed of a new material. We learned of a material developed by an aerospace vendor. This material was developed because of a serious problem encountered in commercial aircraft. Specifically, continuous vibrations of the craft cause abrasion and failure of electrical wires. This new material is being used in aircraft wire harness clamps that hold wire in place. It has an extraordinary capacity to deaden vibrations when used in our Vibra-killers feet. Customers are putting it up against the most touted competing product and are reporting back that ours is significantly better. While the material is, of course, important, the shape of the feet and the design of the retention device is also very important. Ours are unique in this respect and we believe they are very effective. Their shape and design of the bottom retainer tray also enables them to self-adjust their rigidity for varying weights. This is why they can be used for components as light as CD players, turntables, and amplifiers weighing as much as 28 pounds (set of four feet). Vibra-Killers will not cause rings on your furniture or mar the finish in any way. (Sorbothane will. Vibrapod will as they state in their web site) We are offering this product in the heavy duty size of 2" diameter base, 1 1/8" high. Should your component weigh more than 28 pounds, place more feet under the component. Each foot supports up to 7 pounds. There is no need to permanently attach the feet to your components. Simply place the component on top of the feet. The damping effect of this new extraordinary material provides significantly tighter bass and improved detail over the entire audio frequency range as well as heighten transparency, speed of transience and dynamics - all of which provides for a very natural presentation. The Competition: Some charge up to several times as much. Available now@ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 62911106 BUSINESS HOURS: MON-SAT: 12.30-8PM daily. SUN & PUBLIC HOLIDAY: CLOSE.
We are pleased to announce the arrival of Audioprism's long awaited Ground Control Leads. Available in: 1.Reference RCA@ $225.00/each nett. 2.Reference Spade@ $360.00/pair nett. 3.Reference Banana@ $360.00/pair nett. 4.Standard Spade@ $225.00/pair nett. Reviews: http://stereotimes.com/comm071910.shtml http://sixmoons.com/audioreviews/groundcon...undcontrol.html http://forum.audiogon.com/cgi-bin/frr.pl?r...d-Control-Tweak Please visit: www.musiclinkav.com for more details. Available now@ Musiclink AV Distribution 100 Beach Road, #02-46-49 Shaw Tower Singapore 189702 Tel: 62911106 Business Hours: 12.30-8pm daily Mon-Sat. Sun: Closed
New arrival for 2010@ Musiclink. Introductory offer: $60.00/each Affordable Acoustic System Quad Power Distributor for the budget tight Audiophile. SOLD OUT our 1st shipment. 2nd shipment just arrived! Hurry while stocks last! Check it out soon@ Musiclink. Please also visit our web-store www.musiclinkav.com for other hifi or AV goodies. Available now@ Musiclink AV Distribution 100 Beach Road, #02-46-49 Shaw Tower Singapore 189702 Tel: 62911106 Business Hours: Mon-Sat: 12.30-8pm daily. Sun & Public Holiday: Close
Check out Furutech's FS-303, 301 & 502 cryogenic & demagnetize speaker cables. PROMO: Purchased a minimum of 6m from any of the following models, we will OFFER you 8 pcs of Ambiance Banana or Spade connectors worth $24.00 absolutely FREE. Hurry While stocks Last! <FS-303> Usual Price@$10.00/m. Promo Price@$8.00/m 16 AWG α(Alpha)-Conductor(1.54 sq.mm),Material:μ-OFC *α(Alpha)-Conductor---The fine μ-OFC Conductor are treated by α(Alpha) Process (Super Cryogenic & Demagnetize Treatment .) * Conductor:α(Alpha)Conductor(μ-OFC:7/28/0.10mm) * Insulation:Flexible PVC (White pearl) * Max. Conductor Resistance: 0.023Ω/M * Outside Size: Diameter 4.0 × 8.0 mm (≒15 AWG) / (1.54 sq.mm) <FS-301> Usual Price@$15.00/m. Promo Price@$12.00/m 14 AWG α(Alpha) Conductor(1.87 sq.mm),Material:μ-OFC *α(Alpha)-Conductor---The fine μ-OFC Conductor are treated by α(Alpha) Process (Super Cryogenic & Demagnetize Treatment .) * Conductor:α(Alpha) Conductor(μ-OFC:7/34/0.10mm) * Insulation: PE (Red、White) * Sheath:Flexible PVC(Pearl White) * Diameter:7.5 mm (≒14 AWG) / (1.87 sq.mm) * Max. Conductor Resistanc:0.0135Ω/M <FS-502> Usual Price@$25.00/m. Promo Price@$22.00/m 14 AWG α-Conductor(1.98 sq.mm) ※α-Conductor :The fine μ–OFC conductor wire strands and treated by α(Alpha) process. *Conductor:α-Conductor (7X36X 0.1mm) * Material:μ-OFC * Insulation : Polyethylene * Filler:Cotton Yarn * Shield : PET/Al Tape+α-Conductor wire 7X0.2mm Braid * Sheath : Flexible PVC * Max Conductor Resistance : 0.0125Ω/M * Overall Diameter :8.0 mm (14 AWG)/(2.0 sq.mm) On Promo Now@ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 65-62911106 BUSINESS HOURS: MON-SAT: 12.30-8PM daily. SUN & PUBLIC HOLIDAY: CLOSE
New shipment has arrived for LAT AC2-MK2. Hurry SOLD our 4th spool of 100m. We are into our 5th spool. Hurry get it soon! While stocks last! Special Promo Price@ S$99.00/M. Usual Price@ $188.00/M. FREE WATTGATE 320i IEC + WATTGATE/MARINCO 5266i US plug or WATTGATE 320i IEC + PermaPLug UK plug with a minimum purchase of 2m length of the AC2 MK2. To further sweeten the perks, we will also throw in braid coverings to protect your purchase. Hurry While Stocks Last! Buy a minimum of 2m of the AC-2MK2, we will offer you a pair of Wattgate 320i IEC + Marinco/Wattgate 5266i US power plug or Wattgate 320i IEC + Perma Plug UK power plugs are absolutely FREE. No, your eyes are not playing tricks on you and neither are our fingers having cramps to TYPE such a mistake. Hurry While Stocks Last! Promo starts this Monday 1 Nov 2010 and ends 31 Dec 2010. Promotion extended due to popular demand! AC-2 MK II One of the Finest Power Cords Anyone who is knowledgeable of power cords in the High-End industry and is also knowledgeable of those that receive great recommendations, will, I am sure, know of the reputation of our original AC-2 power cord. However, we work continually in developing improvements to all of our cables. This 10 gauge AC-2 MK II is a significant upgrade to the original. Improvements include a new and more effective weaving geometry, 6 nines OFHC (Oxygen Free High Conductivity Copper) and improved shielding to provide for elimination of RF and EMI interferences. Insulation is upgraded from FEP Teflon to PTFE Teflon; more costly; but the best insulation available. Our proprietary Silverfuse conductor material is also used on this cable. See an explanation of the Siverfuse process further down on this page. Connectors are also upgraded; we built this cord with a heavy duty IEC female connector (Wattgate) at the component end and at the wall receptacle end, the well respected audio grade Wattgate/Marinco plug. Customers tell us they have compared this cable to far more expensive cords and have found ours to perform far better. You can see their exact comments at audio review. We have also included a heavy-duty outer jacket to protect the interior and to also prevent against sharp bending of the cable. We have found that cables that do not have this additional protection, if bent too sharply, can be susceptible to sustaining small fissures (cracks) in the conductor which, over a period of time; can degrade the performance of the cable. This is one of the reasons that used cable gets into the used cable market. Performance has deteriorated and usually the former owner does not realize why. This is especially true of cables that use a plastic mesh as their only outer protection. Plastic mesh outer coverings are a sign of a hand made cable; (see our “Cable Hype” page in our web site concerning the problems with hand made cables). We are proud that our customers tell us that this is truly an outstanding power cord. EXPLANATION OF OUR PROPRIETARY SILVERFUSE CONDUCTOR MATERIAL: Silverfuse is a near alloy of silver and copper. The copper used in this process is Single Crystal Continuous Cast Copper. It has unique physical and chemical properties, such as considerably longer granules with absolute absence of gaseous impurities such as oxygen, carbon, hydrogen and nitrogen. It is free from impurities (up to 99.99998% pure copper). It is far better than continuous cast Oxygen Free High Conductivity wire (OFHC). IT IS NOT SILVER PLATED. Silver plating causes a dioding effect when signal is passing through resulting in brightness and distortion. Because silver plating has a bad reputation, some manufacturers try to disguise the fact by calling it silver coated, silver clad or silver/copper hybrid. But they are all silver plated. Our Silverfuse process starts with Single Crystal Continuous Cast Copper wire with a diameter that is slightly larger than the required size. It is then pulled through a trough of molten silver. The wire with a silver deposit is then forced through a compacting process where it is subject to tremendous pressure. The silver and the copper are fused together into a near alloy. The compacting fusion also reduces the wire diameter to the desired size. No dioding subsequently occurs with this process. The result provides for the benefits of silver; which are excellent definition and clarity, with the high purity copper benefits of warmth and mellowness. (Incidentally, pure silver wire also causes brightness) Please note that we have available power cords as short as 1.5 meters (4.92 ft.). However, any length shorter than 1.8 meters (5.9 feet)will begin to degrade the effectiveness of the shielding and filtering capabilities; regardless of who is the manufacturer. Power cords are not like speaker cable and interconnects where shorter is better. Awards & Reviews: HIFI CHOICE RECOMMENDED PRODUCT. PROMO STARTS ON MONDAY 1 NOV 2010@ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 62911106 BUSINESS HOURS: MON-SAT: 12.30-8PM daily. SUN & PUBLIC HOLIDAY: CLOSED.
BERESFORD ENGLAND Caiman-New shipment arrived!, TC-7520-In stock & TC-7510-New shipment arrived! Announcing the arrival of the AWARD winning CAIMAN DAC. UP$517.00/each w/std PSU. PROMO PRICE@ $449.00/each w/std PSU. OPTIONAL REGULATED POWER SUPPLY PSU@$49.00/each. MODEL: TC-7520SE CAIMAN DAC/HEAD-AMP/PRE-AMP (Singapore 230vac version) PRICE: $517.00/each w/std PSU. Intro Price@ $449.00/each w/std PSU. Beresford Caiman is the accumulation of various modifications & the use of the latest high performance components that were proven to enhance the standard TC-7520. Beresford Caiman is the first commercially available DAC to use some of these components, & the only 1 to incorporate so many of them all in one go. Ea Beresford Caiman is individually modified & assembled by hand, before undergoing a test session. Such level of workmanship is unheard of in the DAC market at this price level. But it ensures that each 1 of the limited quantity production run is built to the highest standard & care. Class-A headphone amplifier circuit. The new generations of high-end headphones have up to now only been able to operate properly on expensive stand-alone headphone amplifiers. Inbuilt headphone amplifier is designed to drive even the latest range of high-end headphones & reproduce musical detail that these new headphones are capable of. Dedicated Caiman power supply. ----OPTIONAL PSU@ $49.00/each. Caiman circuitry benefits from a better PSU that can deliver the higher current discharge rate & voltage swing demanded by wide dynamic range & complex musical passages.The Caiman PSU delivers an additinonal 3Volts Peak to Peak of supply headrooom. The result is firmer and deeper bass, more detailed midrange, & greater soundstage in the treble region. For Mac users using the optical output found behind the 3.5mm stereo socket, we have the special optical adaptor in stock@ $5.00/each. Latest addition to further IMPROVE your already HOT Beresford DAC. Introducing the even HOTTER CI-AUDIO VAC-1 High Current PSU! VAC-1 will improve bass definition, dynamics, lower background noise, clarity as well as improve details especially micro details-Its awesome!Promo Price@ $299.00/each. Free Sonilink DC-DC silver powercord worth $99.00/each w/every purchase! With customers coming all the way from Dubai & India to purchase Besreford's 3 awesome DACs, Need we say more?? Selling Fast! HOT! HOT! [glow=yellow,2,300]New Beresford PSU arrived! We would like to invite all existing owners of Beresford TC-7510 & 7520 to try out their new PSU. Expect improvement in sound quality, details, better bass definitions, mids & highs when compared to your existing PSU. Get yours today @ $38.00/each.[/glow] HOT DEAL! FREE DIGITAL + OPTICAL CABLE worth $108.00 WITH EVERY PURCHASE! WHILE STOCKS LAST! Purchase w/Purchase-To sweeten the deal further we are offering the New Audioplus Audiophile USB cable valued @ $199.00/2m each to customers who purchased the Beresford TC-7520 @ a reduced price of just $99.00/2m each. Limited to 1 cable per TC-7520. For customers who bought the TC-7520 prior to this promo, you are also welcome to purchase the Audioplus USB @ $99.00/each. MODEL: TC-7510 MK6/4 DAC/HEAD-AMP/PRE-AMP (Singapore 230vac version) PRICE: $299.00/each. Intro Price@ $249.00 The Beresford TC-7510 is an uncomplicated D to A Converter with design features offering the ideal solution for the modern day high technology home hi-fi or multi-media environment. Most D to A converters are aimed at the CD and DVD audiophiles. The TC-7510 has however been designed for a broader range of application & has been further optimized for accurate PC & wireless digital audio reproduction. That includes wireless servers such as the SB3, Airport Express, DAB radio, & satellite audio. MODEL: TC-7520 DAC/HEAD-AMP/PRE-AMP PRICE: $399.00 Intro Price@ $349.00/each. Beresford TC-7520 is an uncomplicated D to A Converter w/cutting edge design features that offer affordable solutions for the modern day high technology home hi-fi or multi-media environment. Most D to A converters are aimed at the CD and DVD audiophiles. The TC-7520 has however been designed for a broader range of application & has been further optimized for accurate PC & wireless digital audio reproduction. That includes wireless servers such as the SB3, Airport Express, DAB radio, satellite audio, & internet radio streams. The TC-7520 is a 4 inputs audio DAC with 24bit/96KHz digital input capability. It has two re-clocking circuits, compared to none or just one on other DACs on the market. One re-clocking circuit handles just the incoming USB data. This is to prevent us having to design a compromised clock with multi purpose ability. The results from the TC-7520 must rate as one of the best available from any USB DAC at any price. A second re-clocking circuit handles the SPDIF signals. The resulting detail in even 128kbs mp3 files is even better than many CD/DVD only capable DACs. The LINE output stage of the TC-7520 consists of a fixed output & a variable output. The fixed output should be connected to a preamp or integrated amp. The Variable output allows the TC-7520 to be used as a preamp. The headphone amp is a completely new design & can hold its own against stand alone headphone amplifiers costing several times the price of the TC-7520. Extensive research has allowed us to design a headphone amp that does not produce that boomy midhead sound of conventional headphone amps. Neither does it produce the lack of bass & signal cancellation side effects of a cross-feed headphone amplifier. What the TC-7520 headphone amp does do is produce one of the best soundstage with outstanding detail & excellent headphone load handling ability. Its almost binaural response sounds far more natural & involved than a cross-feed design. Analog Audio: Separate Left & Right audio ICs are behind the audio capabilities of the TC-7520 headphone amp. This is only used for the headphone amplifier output. Audio to the external headphone & line outputs is not processed this way, only level control is adjustable in the digital domain for these ports. A ¼” headphone socket is driven by a dedicated headphone amplifier, which is a highcurrent amplifier that is capable of driving a wide variety of headphone loads, & even outperforms many external headphone amps costing more than a complete TC-7520. The Volume Control sets the output level of the headphone socket. It can also be used to control the output level of the Variable RCA analog outputs. The TC-7520 is designed to connect directly to power amps & powered speakers in order to provide the cleanest & shortest path from digital to monitor output. Audio for the stereo headphone socket & stereo line output sockets are all treated separately. This means that the two types of outputs are separately amplified & there should be no interaction with loading on the various ports. However the audio output to all analog outputs are the same. You cannot send 1 audio feed to the headphones & another to the line output, both will always play the same audio. The analogue audio output stage & headphone amplifier operates in Class A. This means that there is no crossover distortion in the audio output, which results in a fuller & better dimensioned sound. The TC-7520 cost versus performance is more in the hi-end league. The cleverly designed analogue layout helps to maintain minute details, depth, & punch in the information retrieval of the digital audio signal. We have also paid great attention to sound stage & sonic depth, giving the TC-7520 audio performance levels that were previously only available from similar products costing several times the price of the TC-7520. The unique Virtual DC power supply is largely to thank for the leap in performance. The two part external & internal power supply supports all international voltages & has generous margins for over and under voltage conditions. REVIEWS: http://whathifi.com/Review/Beresford-Caiman/ http://www.whathifi.com/Review/Beresford-TC-7510/ HI-FI CHOICE BEST BUY- At this kind of price its impressive that a small manufacturer can make a DAC at all to make one this good is an admirable achievement. Remarks: Above Pricing exclude GST. Please also visit our web-store@ www.musiclinkav.com Audition now @ Musiclink AV Distribution 100 Beach Road, #02-46-49 Shaw Tower Singapore 189702 tel: 65-62911106 Mon-Sat: 12.30-8pm daily. Sun: Closed
New arrival@ Musiclink Introducing the new Furutech FP-704 Stereo Gold Plated headphone 1/4" connector. Price reasonably to accomodate even the tightest budget head-fi audiophile. Usual Price@ $28.00/each. Promo Price now@ $22.00/each. High Performance Phone Jackets FP-703(G) 24k Gold-Plated (Mono) FP-704(G) 24k Gold-Plated (Stereo) STEREO 2006 July STEREO 2006 July •? (Alpha) Eutectic cast copper alloy center pin •Copper alloy rear housing with PBT and fiberglass insulation •Specified for cable diameters up to 8mm •Connections: Soldered •Zn-Mg Alloy Casting body housing Dimensions: •FP-703: Housing---17.8± 0.1mm diameter X65.8mm± 0.1mm,97.3mm± 0.1mm overall length •FP-704: Housing---17.8± 0.1mm diameter X65.8mm± 0.1mm,97.8mm± 0.1mm overall length Available now@ MUSICLINK AV DISTRIBUTION 100 BEACH #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 62911106 BUSINESS HOURS: 12.30-8PM DAILY. SUN: CLOSED
New arrival@ MUSICLINK Introducing Furutech's new FI-8N figure 8 power connector. Available in Rhodium & Gold plating. Price: Please call for pricing. FI-8N Series New for 2009! High End Performance FI-8N IEC Connectors C7 IEC • Furutech’s unique female conductor design features α (Alpha) Beryllium copper and Phosphor Bronze conductors • Material: Nylon/ fiber glass body/cover and polycarbonate cable clamp. • Specified for cable outer diameters of 6.0mm ~ 13.0mm • Wire accommodation: Max. 2.4mm dia.(Solid core) // 2.0 Sq.mm/14AWG (Strand wire) • Connections: Set screw. • Dimensions: 36.8mm X 28.2mm X 71.0 mm ± 0.5mm overall length Please also visit our web-store@ www.musiclinkav.com for more must have hi-fi & AV goodies. Available now@ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 62911106 BUSINESS HOURS: MON-SAT: 12.30-8pm daily. SUN & PUBLIC HOLIDAY: CLOSED
New arrival @ Musiclink Introducing Furutech's SILVER PLATED PCOCC+ USB cable. Price@ $160.00/1.2m Features • Main conductor: Silver-plated α (Alpha) OCC Conductors • Main Insulation: Special-grade high-density polyethylene • 3-layer shield construction for improved noise insulation • Connectors: Furutech-engineered 24k gold-plated USB series Connectors • The best damping and insulation materials for improved frequency extension and tonal balance • Cable Types - GT2 USB-A(Type A-A)-indent basis only - USB-B(Type A--in stock - USB-mini B(Type A-mini -indent basis only -Available length: 0.6m (2ft) / 1.2m (4ft) / 1.8M (6ft)-In stock 3.6m (12ft) / 5.0m (16.5ft) / 7.0m (23ft) and 10.0m (33ft) by indent basis only AWARDS & REVIEWS: Visual GranPrix Award Japan 2010 Visual GranPrix Award Japan2010 Summer gold prize Please also visit our web-store@ www.musiclinkav.com for other must have hi-fi & AV goodies. Available now@ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 62911106 BUSINESS HOURS: MON-SAT: 12.30-8PM daily. SUN & PUBLIC HOLIDAY: CLOSED.
