Stereo_Electronics
Silclear back in stock!
Silclear in stock at our Plaza Singapura outlet, Causeway point outlet will have stock tomorrow 2nd Aug.
IPB Image
SilClear is the first-ever silver contact lube optimized for good sound, not thermal conductivity. The secret is microscopically thin silver platelets (a millionth inch thin; 8 square feet of surface per gram!) to enhance beneficial skin effect. The unique binder for these platelets is an ultra-pure, low dielectric absorption, food-grade grease to minimize signal loss/smearing. The thinnest possible coating lasts 10 to 20 unpluggings.
Silclear's initial sonic enhancement improves significantly with continuous playback.You will hear overall system warmth and depth continue to improve for at least 4 to 10 hours.
What else you can treat with Silclear:
- XLR, BNC, DIN plugs
- Cartridge pin clips and tone arm wire plugs
- All tube pins
- Amplifier and speaker ground wire binding posts.
- All fuse contact surfaces
- FM antenna wire connections
- TV antenna connections
- Power cords
Just remember not to leave excess Silclear or thin lumps when applying.
Comes in a 14-gram jar (with applicator) that treats 1000+ connectors.
