heady 0 Report post Posted August 22, 2009 http://www.head-fi.org/forums/f6/gamma-2-2...tml#post5949860 Gentlemen, fellow DIYers, Warm up your soldering irons! Seems AMB has sent the y2 boards for manufacturing. Any one interested? Please note that you will also need to order a y1 board at the same time. If got interest, then I will try to organise the group buy. Maybe mouz will help? Buying the boards is the easy part, getting the BOM will be more challenging, especially for us in SG. If can get all the parts from Farnell, then no sweat. But if need to buy from Digi-Key, then a bit problem if done individually. So a group buy will make sense. What say you all? Regards. Quote Share this post Link to post Share on other sites
gene83 0 Report post Posted August 22, 2009 Hey Uncle Heady, sign me up man. Quote Share this post Link to post Share on other sites
direcow 0 Report post Posted August 23, 2009 sounds like fun hopefully I don't botch it. Quote Share this post Link to post Share on other sites
gene83 0 Report post Posted August 23, 2009 hey dire, you need a y1 to work with the y2. thats a pre-requisite. Quote Share this post Link to post Share on other sites
ckng 0 Report post Posted August 23, 2009 What's the cost going to be like? And any idea if it does 24/96 via USB? The AMB page doesn't mention this. Regards CK Quote Share this post Link to post Share on other sites
mouz 0 Report post Posted August 23, 2009 (edited) Oh yes! count me in. Heady, feel free to contact me if you need help in anything I'll help with the face plates as usual too. BTW, tot you could break open the Y1 and use it with the Y2 board too right? Edited August 23, 2009 by mouz Quote Share this post Link to post Share on other sites
heady 0 Report post Posted August 23, 2009 Oh yes! count me in. Heady, feel free to contact me if you need help in anything I'll help with the face plates as usual too. BTW, tot you could break open the Y1 and use it with the Y2 board too right? Can reuse the y1 we built but sayang lah, after putting into nice case with panels. Aiyah, might as well buy another and built it from new. Building it is not difficult but buying the parts were a pain. I dunno why I so itchy. Now I am listening to a USB-Monica+Mojo feeding a SOHA-JISBO amping a DT150 and it's so blissful listening to Diana Krall. But we DIYers must built, right? Quote Share this post Link to post Share on other sites
mouz 0 Report post Posted August 24, 2009 Haha yah, but for my case time and budget constraint lah. So no choice gotta take short cuts Quote Share this post Link to post Share on other sites
adn6244 0 Report post Posted August 25, 2009 heady & mouz, I'm in too! I know this will happen just a matter of time Quote Share this post Link to post Share on other sites
heady 0 Report post Posted August 30, 2009 Guys, I will post the group buy as soon as the boards become available. Let's hope this will be soon. If any one of you guys have the time, please find out what's available from Farnell and what we need to get from Digikey. It will make things easier when we set up the group buy. I will be busy for the next 3 weeks and will not have much time to set this up. Any help will be appreciated. Thanks. Quote Share this post Link to post Share on other sites
mouz 0 Report post Posted September 2, 2009 (edited) Ok guys, here's what I can dig out. As you can see I got most of the stuff from mouser as they got most of the parts. Total cost for items below is about $121.42 without the stuff from AMB. Suggest maybe try to pair up in groups of 2 to get their free delivery here. Farnell - SGD27.42 1015173, 1, Box Enclosures B2-080BK Mouser - SGD94.17 649-68786-202LF|1|2P jumper 80-C320C104K5R|9|0.1uF X7R 80-C315C103K5R|2|10nF X7R 505-FKP2100/100/2.5|4|100pF film 505-FKP2220/100/2.5|4|220pF film 661-PSA10VB47M|2|47uF polymer electrolytic 647-UKW1H220MDD|2|22uF audio-grade 647-UKW1A471MED|2|470uF audio-grade Use (use this if you're driving headphones directly, otherwise stick to 22uF) 71-RN50C3321F|4|3K3 miniature 1% 71-RN50C-F-2K|4|2K miniature 1% 71-RN50C-F-4.75K|4|4K7 miniature 1% 71-RN50C-F-47.5K|2|47K miniature 1% 595-TPS793475DBVR|1|TPS793475DBVR 595-TPS79333DBVR|1|TPS79333DBVR 579-MCP100-315DI/TO|1|MCP100-315DI (ordered only 1 for this based on assumption no one will be using WM8740) 595-SRC4192IDB|1|SRC4192IDB (everyone wants upsampling I suppose) 238-WM8741GEDS/V|1|WM8741GEDS (there are others like WM8742 and WM8740) 595-OPA2365AID|1|OPA2365AID (using this as mouser doesn't have stock for AD8656) 549-C3391-24.576|1|rystek C3391 24.576MHz 633-G13AV-RO|1|SPDT on-off-on 633-G12AV-RO|1|SPDT on-none-on 517-850-01-08|1|Pin receptacle AMB - ? γ2 PCB C19 / 1uF film / - / - / - / - / AMB / - C25 / 1uF film / - / - / - / - / AMB / - R1 / 68Rx4 resistor network SIP-8 isolated / - / - / - / - / AMB / - R2 / 68Rx4 resistor network SIP-8 isolated / - / - / - / - / AMB / - Ferrite Beads: L1 / ferrite bead / - / - / - / - / AMB / supplied with γ2 PCB L2 / ferrite bead / - / - / - / - / AMB / supplied with γ2 PCB L3 / ferrite bead / - / - / - / - / AMB / supplied with γ2 PCB L4 / ferrite bead / - / - / - / - / AMB / supplied with γ2 PCB L5 / ferrite bead / - / - / - / - / AMB / supplied with γ2 PCB Connectors/Jacks: J6 / RCA jack / - / - / - / - / AMB / - J7 / RCA jack / - / - / - / - / AMB / - J8 / 3.5mm stereo mini-jack / - / - / - / - / AMB / - J4 / 5P long pin header / - / - / - / - / AMB / supplied with γ2 PCB J5 / 3P long pin header / - / - / - / - / AMB / supplied with γ2 PCB If you're a fan of farnell, you might wanna refer to this list. Some missing parts though... Farnell 1015173, 1, Box Enclosures B2-080BK 1457655, 9, 0.1uF X7R 1457653, 2, 10nF X7R 1005979, 4, Wima 100pF film 1005983, 4, Wima 220pF film 9189505, 2, 47uF polymer electrolytic 8766959, 2, 22uF audio-grade 8766762, 2, 22uF audio-grade 9343040, 4, 3K3 miniature 1% 9342788, 4, 2K miniature 1% 9343253, 4, 4K7 miniature 1% 9343261, 2, 47K miniature 1% 1652322, 1, TPS79333DBVR 1212673, 2, MCP100-315DI (Install U6 only if you are using a WM8740 for U5) 8452741, 1, SRC4192IDB (Install U4 if you want the upsampling feature) 1329587, 1, OPA2365AID 1524234, 1, SPDT on-off-on (SW1 and SW2 should not be installed if U5 is a WM8740 -- Short the FSEL and ACLIP pads to GND) 1524233, 1, SPDT on-none-on (SW1 and SW2 should not be installed if U5 is a WM8740 -- Short the FSEL and ACLIP pads to GND) Edited September 23, 2009 by mouz Quote Share this post Link to post Share on other sites
stephen chung 0 Report post Posted September 8, 2009 MOUZ, Keep me in the loop... Stephen Quote Share this post Link to post Share on other sites
madwolf 0 Report post Posted September 18, 2009 I am interested. It does not do 24bit/96K as the USB converter is PCM2707. I already have the voltage converters, USB chip, reset chips, OP-AMP But could join in if there is a complete BOM available. Quote Share this post Link to post Share on other sites
Duck-in-the-Box 0 Report post Posted September 18, 2009 that's the price with y1? Quote Share this post Link to post Share on other sites
mouz 0 Report post Posted September 18, 2009 Nope that's only the parts for y2 with no PCB. Throw in the y1 to make it complete would be about another 100 odd I think. Madwolf, doubt there will be a complete BOM available. Any help in this area would be very much appreciated though. Quote Share this post Link to post Share on other sites
