SvenMZ8
SvenMZ8 Audio DIY thread
something for u guys to try.
experiment one
say copper and silver cables in an interconnect.
one copper and one silver for all the three channels
but...add capacitors parallel across the copper and silver
ipod----------silver----------------amp
xxxxx | xxxxxxxxxxxxxxxxx |
xxxxx = xxxxxxxxxxxxxxxxx =
xxxxx --------copper-------------
Note: Ignore the "x"s, they are there to counter the forum's post filtering, "=" sign is capacitor
this should add a delay, maybe allows the vocals or drum beats echo longer.
capacitor values can be experimented too.
experiment two
as u know there exist several blends of solder
-regular solder
-cardas eutentic
-mundorf silver
how does each affect the sound?
-we only use a minute amount in the lod and mini jack.
what if we use them as the transmitting cable itself?
experiment three
hybrid cables
in making hybrid cables we connect copper and silver cables end to end from lod to mini.
what if
ipod-------------copper------+++
xxxxxxxxxxxxxxxxxxxxxx +++---------------silver--------------mini
experiment four
imods 5g/5.5g video
sending the lineout to headphone out. there are several reasons for doing so.
-no need for lineout docks
-near zero risk of wires breaking loose to the pads
-right angle to right angle interconnects to external caps, resulting in simpler and compact implementation.
the pads for doing this should be the large yellow caps underside of the clickwheel connector.
hope to hear from you ambitious diyers out there.=)
Edited by SvenMZ8
Low profile imod lod, silver, blackgates
another low profile lod, silver, for rsa shadow
imod video 5g 32gb CF flash card with internal blackgates
Mogami Japan Copper
Balanced Headphone Amp
Balanced headphone to single ended using headphone splitter
Edited by SvenMZ8
have some noobish qns to ask
for a ipod 5th gen mod do u remove the cap n inductors?
or do u leave them and if u do remove them would u still be able to use ho?
so the HO doesnt work anymore i guess?
n btw i read that LOD for 5g imod need caps in them do u happen to know what cap/volt i should use?
and best if u know where i can get them like elna silmic 2 or bg
Create an account
Register a new account
Sign in
