musiclinkav 0 Report post Posted March 26, 2010 ACOUSTIC SYSTEM USA Promo Price@ $899.00/pair. Single Stereo unit@ $450.00/each. Free Audioplus 2.5m PCOCC+ Speaker Cable worth $299.00 with every purchase! While Stock Last! Model: PA-150 MONO/STEREO POWER AMPLIFIER PRICE: UP:$1599.00/PAIR INTRO PRICE@ $899.00/PAIR PRICE: UP:$900.00/EACH INTRO PRICE@ $450.00/EACH(SINGLE UNIT FOR STEREO APPLICATION)Fancy a pair of affordable mono blocks or a single stereo power amplifier? Look no further, introducing the Acoustic System PA-150 Mono/Stereo Power amplifier. Designed with audio grade components producing superb sound quality. Acoustic System Electronics are designed like no other! Audition it today to check out this awesome amplifier. Amplifiers today need to be multi-faceted to keep up with the task at hand. Versatility is the foundation upon which the Acoustic System PA150 is based. Configured in stereo mode, amplification is provided to a pair of speakers for stereo or surround playback. Select bridge-mono mode and the PA150 is configured for Mono Block duties for a pair of loudspeaker. It can also be used for powering a center channel speaker, or a subwoofer/tactile transducer when used with the on-board low pass filter. Full-range line-level outputs allow for daisy chaining amplifiers for a multi-room whole house audio system or for bi-amp applications. A smaller chassis consumes less space than conventional amplifiers making placement options virtually endless. Key features of the PA150 are high current, discrete power transistors (used in premium amp designs), a hefty toroidal power supply transformer, low-noise forced air cooling, a fully adjustable—and defeatable—electronic 50-150 Hz low-pass filter (18 dB/octave), and complete protection against electrical shorting and thermal overload. Also included is auto-on/off, silent turn-off with no audible transient, gold plated RCA inputs/outputs, and 5-way binding posts. Features and Specifications: *Measured power output: 2 x 75 watts RMS (into 4 ohms @ less than 0.01% THD) *Signal-to-noise ratio: greater than 100 dB *Class A/B design topology *Input impedance: 47k ohms *Auto-on sensitivity: 3 mV *Voltage requirement: 120/230 VAC, 60/50 Hz *Dimensions: 5-1/2" H x 6" W x 11-1/2" D. *Toroidal power supply *2 x 75 watts RMS power @ 4 ohms, 1 x 150 watts RMS bridged mono @ 8 ohms *High current, discrete output transistors *Adjustable 50-150 Hz low pass crossover *Gold-plated 5-way binding posts that accept up to 8 AWG wireAudition today@ MUSICLINK AV DISTRIBUTION 100 BEACH ROAD, #02-46-49 SHAW TOWER SINGAPORE 189702 TEL: 65-62911106 BUSINESS HOURS: Mon-Sat:12.30-8PM daily. Sun : Closed Share this post Link to post Share on other sites
musiclinkav 0 Report post Posted May 7, 2010 CHECK IT OUT SOON! VISIT OUR NEW WEB-STORE: MUSICLINK'S WEB-STORE Share this post Link to post Share on other sites
