skyaudio 0 Report post Posted April 27, 2010 (edited) Introducing Pure Class A Separate Power Headphone Amp from Amtech http://www.da-t.com Listed price: S$880 Promotional Price: S$700 Features: 1. Low output impedance of <0.3ohm. Able to drive any headphone with any impedance. 2. Extremely low THD of <0.004%, enable the pure and complete signal to your Headphone 3. Strong Power output: 9W @ 8ohm, 2.25W @32ohm. 4. Separate power supply with 52VA toroidal transformer 5. Adjustable output power for headphone with difference impedance 6. Can be excellent preamp due to the extremely low THD and the low output impedance. Specifications: 1. Contunuous Average Output Power: 2.25w per channel into 32ohm 1.125w per channel into 64ohm 560mw per channel into 120ohm 280mw per channel into 250ohm 240mw per channel into 300ohm 120mw per channel into 600ohm 2. Frequency Response: 7hz-340khz, +0dB - 3dB 3.Total Harmonic Distortion(THD): <0.004% with 32 ohm load 4. Gain: 6 to 26dB variable 5. Bias Current: 26mA to 187mA variable 6. S/N Ratio (A-weighted): 115dB 7. Slewing Rate: 73v/us 8. Input Impedance: 47k ohm 9. Output Impedance: <0.3 ohm 10. Peak Voltage output: 24Vp-p 11. Peak Current Output: 1A 12. Weight: 1.2 kgs 13 Dimension (mm): 34H x 205D x 100W Some pictures to share: - You are welcome to bring your Headphone and favorite CDs for audition. Best Regards Steve Sky Audio 19 Lor Kilat #01-06 Singapore 598120 Tel: 6762 5890 Edited April 27, 2010 by skyaudio Share this post Link to post Share on other sites
