Guest crashie
Misunderstand sijosae schematic! help urgent
Guest crashie
Hi, i got a problem with the schematic. why do we need 2 heater supply to operate one filament? thanks
It is correct. The 2 LM317's are not configured as voltage regulators. They are configured as Constant Current sources.
Hence, by calculation, each of them are sinking 1.25v/( (15*20)/(15+20) ) = 0.146A.
Therefore, instead of driving the filament with a fixed voltage and obtaining the current flow by the resistance of the filament, both current sources sink nearly 0.3A together through the filament.
This negates the need for a separate voltage source/ regulation for the filament.
A regulated supply connected across the filaments would stabilized at a fixed current after warming up but this design allows for regulated current through the filament regardless of the voltage supply.
Guest jacj6049
Should be correct, in this case, the voltage is split between the 2 filaments. Check out this, similar design, http://diyaudioprojects.com/Solid/12AU7-IR...-LM317-Headamp/.
The filament wiring is explained in the article.
hi,but if i use this diy project to build 2 amps,but one of the amp jus use for ground channel,it is sound better than jus use 1 unit?should be able get al the parts from koba rite?thanks
regards,
It is not recommended. For starters, the amp is not in unity gain, which is what you need for the ground channel.
Secondly, even if you had the 12AU7 in a cathode follower configuration, that design does not have global feedback, which is what you need to ensure that the currents on the ground channel are always balanced.
