funtastick
want to rewire shure se420
hi bros, as above, can anyone help, would be willing to pay for the service, have the wires splitting out of the earphones, i am located in sg, thanks
the tricky part here, is to break open the shell without breaking anything, and place it back nicely
someone did 530, but it wasnt perfect after the shell is assembled
hi, i dont mind if the repair is not perfect, if the earphone remains usable....will pay for the repair, can anyone help?? thanks
ehh who will take the risk for you....
you think properly to open up the shell, is like opening a walnut
why not you try opening yourself, and if a success, you may ask someone to replace cable for you.
Edited by alamakazam
Possible quick, dirty solution to split cables - heat-shrink tape. Not a perfect solution like heat shrink tubing, but it should* hold up for a while.
* disclaimer: haven't tried it out personally. Attempt at your own risk.
Edited by radioactive28
