niccon 0 Report post Posted August 9, 2010 Have been getting hooked to diy after my last try recently and wishes to do more in future. I used a switchcraft 3.5mm jack the last round. Although its construction & appearance are good, i found the centre pin (left channel?) hard to solder. I wonder it was due to my lack of experience, under rated solder iron (using 30w now) or wrong tactic. I tried melting a small pool of solder on pin but found it hard to stay on it. After solder stays on the pin, I reheat the solder to melt it before bringing in the exposed wire. The reheat took a long while. Also I found great difficult to melt some solder on the exposed wire that I gave up trying after a while. I do it by placing the soldering tip on the wire and solder behind the wire. Did I do it correctly? Please advise for more fun experience in my next attempt. Thanks. Share this post Link to post Share on other sites
heady 0 Report post Posted August 9, 2010 Usually a higher wattage iron will heat parts up faster and so will work better with soldering. An iron with temperature control is best. Share this post Link to post Share on other sites
