beetlez
Tube Amps for Grado 325is
Please recommend me a tube amp to go with Grado 325is.
I'm thinking of getting the LD MKIV SE.
But read on Internet that LD MK I+ will do the job.
Not sure what is the sonic difference between hybrid and full tube design.
Any experts to throw some light?
hybrid is a SS + tube stage.
It has the tube biasing for the sound but the robustness of the SS.
this maybe cheaper for most people to have as it's cheaper to make a full SS than a tube power amp. (Tubes need a good transformer and a high voltage one)
The sonic difference is that you get the mids of the tubes yet the highs and lows of the SS.
Personally after hearing a full tube setup, the hybrid can pass off if you do not know what full tube amps sound like - Pre and power..
If you've heard a full tube setup, you will never compromise or have a hard time reconciling the SS and the tube sound because it sounds quite unnatural - the SS tends to over power the tubes.
Personally I've heard the LD and I don't like it, it is too weak to drive some cans fully.
For tubes, the bigger the tubes are the better it sounds - hence most highend hifi sets are using at least the 300b for their monoblocs.
Edited by The Audio Hub
