gomamon 0 Report post Posted May 15, 2011 hi all, the left side of my iem is not producing any sounds could it be that the wires are snapped inside? if so, is it fixable? pls advice, thanks Share this post Link to post Share on other sites
alamakazam 0 Report post Posted May 15, 2011 it can be broken anywhere, most common near the plug connector, strain relieve portion , due to plug and plug, strain from 360degree angles the driver portion, due to pull recable? but it will be ugly, u need crack open the iem, if is glued/welded type some stuff are meant to be replace Share this post Link to post Share on other sites
Guest dragonboy Report post Posted May 16, 2011 Usually it's the connector plug that's faulty. You can have it replaced if you are ok with the soldering iron, if not Stereo at PS or CWP will be able to help you. My friends had their connector replaced there due to bad handling. Share this post Link to post Share on other sites
