blackcircle
My works with cmoy amps
my diy amps....including the casings and wires, all are handmade by me.
[attachmentid=4639] [attachmentid=4640] [attachmentid=4641][attachmentid=4642][attachmentid=4643][attachmentid=4644]
the casing is machined drill right? u have a workshop?
singaporean?
uhmm u use lemo connector for input, uniquely yours!
Edited by alamakazam
thanks bro,
i hv a bench drilling m/c and the rest of the aluminium plates are handsawed and file...only send the casing for black anodizing. As for the Lemo connectors you hv to use a special crimping tools to crimp the wires.
yes, i'm s'porean...
Edited by blackcircle
everything are DIYed from board level to casework, i used 6061 aluminium for the casing i've also did some acrylic casing before....as for anodizing, my friend did it for me FOC :)
this is the acrylic casing, the input was pigtailed instead of using connectors and its sounds much better...
[attachmentid=4645] [attachmentid=4646][attachmentid=4647]
Outstanding casework. I have always found casework to be such a pain and also so unrewarding compared to the care and time I put in.
i would like to join, here is a hybrid cmoy which i made and is quite amazing, plastic enclosure is $2 at simlim
and a diy cable
and in action
whats the use of the resistors here? sorry for the noob qn
you mean the resistor on the plug? its one of the koss mod i have seen, its said that it will give more bass clarity :D
