dalethorn
Objective2 headphone amp
Received my JDS Lab O2 couple days ago. Have been running in. First impression is pretty good. Lots of drive, sounds "big" if you get what I mean :)) . Don't even need to pass 11 o'clock on the vol knob on my LCD2s at normal gain. Rather analytical, can be too bright on certain recordings. I'm getting very bad distortion when I switch to high gain even at low volume. Not sure if it's the opamp. Will roll some opamp and see.
That's bad luck - I didn't get any distortion or problems on high gain, driving Senn 800's and other headphones.
updates for the o2 GB here and here
Bro JMWrecks, is my order confirmed?
It could be the headphones, which headphones are you using with the high gain? anyway try to burn in on high.
Edited by Maniacal71
changed to low power opamps today
on the first listen slightly more noise but not tt significant
but more importantly
there bass seems to increase significantly
