musiclinkav
TEAC UD-H01 DAC/HEADPHONE AMP FROM JAPAN
Announcing the arrival of the AWARD winning TEAC UD-H01 DAC-Digital to Analogue Converter. By the way, we will upgrade our free co-axial to a AR-Acoustic Research Digital cable valued@ $88.00/each and the Optical cable to Audioplus new hybrid Optical cable valued @ $60.00/each for customers who purchased the UD-H01 today. Hurry while stocks last!
Usual Price@ $598.00/each. Intro Price@ $515.00/each.
For Today only! FREE 1pc 1.0M AR-Acoustic Research Coaxial Digital cable valued@ $88.00/each.
Free 1pc 1.5M Audioplus Optical Fiber Cable valued@ $60.00/each.(upgraded to this new hybrid model if purchased today)
Free 1pc 2.0m Audioplus Xtreme USB cable valued@ $59.00/each.
The new Reference 01 Series. Future Proof
The UD-H01 is a dual digital/analogue converter containing two BurrBrown® DAC chipsets (Type 1795) and a Tenor® USB Audio Class 2 Interface. Thanks to the highquality nature of these components, digital audio data from an external PC is converted to an analogue signal in high resolution Hi-Fi quality using up to 32 bit, 192 kHz asynchronous conversion technology. The resulting analogue signal can be sent to either a set of active loudspeakers or to an external amplifier. The UD-H01 is supplied with both balanced and unbalanced audio output connectors and a headphone connector complete with separate volume control. Two audio inputs (digital RCA and optical) allow connecting additional sources i.e. CD or DVD player.
Key Features
USB Audio Class2 High-speed Input from PC/MAC
(Tenor 8802)
32-bit/192kHz Dual D/A Convertors
(BurrBrown 1795 x 2)
Up-conversion to 32bit/192kHz
General Specifications:
Supports Asynchronous Transfer Mode
Toroidal-core-Power Transformer
Detachable AC Socket
Headphone Out with Volume Control
Aluminium Front Panel
USB Input: x 1 (USB2.0)
Digital Audio Inputs: x 2 (Coaxial, Optical)
Balanced Audio Output: x 1 (XLR, 1-GND, 2=Hot, 3=Cold)
Audio Output: x 1 (RCA)
Headphone Out: x 1 (6.3mm)
Input Signal Sampling Rate:
44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
Operation:230V AC, 50kHz
Dimensions (W x H x D): 215mm x 55mm x 215mm
For Mac users using the optical output found behind the 3.5mm stereo socket, we have the special optical adaptor in stock@ $5.00/each.
Purchase w/Purchase-To sweeten the deal further we are offering the New OZ AUDIO Silver PowerCord valued @ $199.00/1.5m each to customers who purchased the TEAC UD-H01 DAC @ a reduced price of just $99.00/1.5m each. Limited to 1 cable per UD-H01.
REVIEWS:
http://www.hifichoice.co.uk/news/article.asp?a=9238
Please also visit our web-store@
www.musiclinkav.com
Audition now @
Musiclink AV Distribution
100 Beach Road, #02-46-49
Shaw Tower
Singapore 189702
tel: 65-62911106
Mon-Sat: 12.30-8pm daily.
Sun: Closed
