AudioBasic
Fiio E17 USB DAC Headphones amp @ Audio Basic
Dear Friends,
Fiio Latest E17 USB DAC Headphones amp is @ Audio Basic now.
Specification
● Output Power: >250mW (16Ω Loaded ) ;>30mW (300Ω Loaded)
● Headphone Impedance Range: 16 Ω ~ 300 Ω
● SNR: ≥109dB(A weight)[AMP]; ≥104dB(A weight)[DAC]
● Distortion: <0.001%(AMP); <0.007%(DAC)
● Support sampling rate(Max): 96K/24bit [uSB] ; 192K/24bit [sPDIF]
● Frequency response: 10Hz~100KHz[AMP]; 10Hz~20KHz[DAC]
● Battery capacity, charging time and using time:1500Mah/3.5H/15H
● Size: 96mm x 55mm x 15.2mm
● Weight: 112g
Features:
● Standard MINI USB Interface: connect with PC to make digital audio transfer possible and make battery charge possible
● 3.5mm two-channel Headphone Output: suitable for various headphones with 16Ω~300Ω
● 3.5mm SPDIF input connector: connect with high-definition player and receive PCM signal
● 3.5mm Line In interface: connect with audio output LO&PO of audio players.
● 18 Pin multifunctional interface: to make audio and data transfer possible in conjunction with L7 and E9.
● work indicator: indicate power on/off and charging status
● high-brightness of OLED dot matrix screen: display kinds of working and setting information
● built-in high capacity chargeable Li-ion battery whose use time can reach 15H.
● Meet listening need by adjusting GAIN , BASS, TREBLE or BALANCE.
Cheers.
Audio Basic
1 Coleman Street
#02-33 The Adelphi
Tel: 6338 3245
