Necroist 0 Report post Posted January 8, 2004 Not really static, its like making music like "droot <pause> droot <pause> droot <pause>" My c1,c2 are 16V 470uF caps and I'm only using 1 9V power supply Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted January 8, 2004 sounds like a short somewhere, check the soldering Share this post Link to post Share on other sites
Necroist 0 Report post Posted January 8, 2004 Ok just tested with my HD497, now that sound is gone, but I can hear a background static noise though. And it seems to be reverbing Share this post Link to post Share on other sites
Necroist 0 Report post Posted January 10, 2004 Okay, latest update, the amp now works! But seems like there's some kind of distortion/clipping on my senns mx-500. But the problem doesn't surface here on my hd497 Share this post Link to post Share on other sites
Necroist 0 Report post Posted January 10, 2004 any1 going to SLT lately? can i tag along to get stuff? went down today... like ghost town... need ppl to orientate me round the place. i think i screw up my 1st CMoy. mayb i need to see a done up one. u can look at my i'm still testing the cha47 which is very similar to the cmoy. i took a better pic of my second cmoy hope it will help u Hi tropical, can I ask what is those black "stopper"-like things that u use to cover ur jumpers? Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted January 10, 2004 (edited) they are attached to the metal contacts, used as jumpers contacts on PC, they come in a strip need to cut them to desired number, i bought them at SLT Starlight. i've stop using them, i now mostly use turn-pin IC holders & solder "legs" to my jumpers wires, so the wires can be remove without re-soldering. see the 2 rows of 3 IC holders between the smaller caps, i also use them for the op-amp Edited January 10, 2004 by tropicalrips Share this post Link to post Share on other sites
Necroist 0 Report post Posted January 11, 2004 thanksss tropicalrips, you're my hero man! I'm actually also curious about this the things on the jumper wires (for example at ur grounding wires below ur op-amp) Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted January 11, 2004 they are not jumper wires its a metal contact with a stopper build into it, one side is longer then the other, not sure what they call those u can use them as the "male" side of the connector for the audio cable on your CD-rom Share this post Link to post Share on other sites
