littlemart
AIBBC/Miu Audio Tube headphone/portable amplifier/Pre-amp
Miu Audio iH2 – Tube Portable Headphone Amplifier (New arrival)
The circuitry is carefully design the in order to make the smallest casing but still provide an audiophile quality tube headphone amplifier for the market.Very very small in size and Elegant looking Tube Portable amplifier. A decent Tube portable amplifier easily cost over $1000. Nice sounding especially it comes with a Jan Philips JAN6111WA Tube. This is an improve version 2 from the previous version
  • Vacuum Tube: Philips JAN6111WA
  • Compact size with built-in re-chargable 2200MHA Lithium battery.
  • Super silent circuitary
  • Audiophile-graded parts and components
  • Sound field selector for different music enjoyment
  • Pack inside a Elegant Piano Finish Wooden Box
Selling at $699
Miu Audio MKTP-1 – mini Pre-amp with Headphone amp
Tubed preamplifier with headphone amplifier. With its fashionable iridescent color design and very small dimensions, the MKTP-1 is one of the world’s smallest and most beautiful pre-amplifiers! It a prefect match with the mini power amp Miu Audio MKP-1 as well as to all other mini integrated amplifier of your choice. Pre-amp helps to give extra gain to the power of your amplifier should you think their power is not enough
  • Only 65mm x 25mm x 98mm.
  • Front panel jacks for headphones and iPod/iPhone/MP3 inputs.
  • Rear panel connections for power amplifiers, as well as rear panel line level input for CD.
  • Ideal complement for headphones, iPods, MP3 players and more. Can be used with powered speakers for a complete system. Perfect for obtaining better sound from your PC.
  • Spectacular audio performance!
  • using 6922EH Pre-amp Tube
*Supports two major tube series:
(1) 6DJ8, 6922, 6N11, 6H23n, ECC88, E88CC, etc., and
(2) 12AU7, 5963, 5814, ECC82, etc
Selling at $160
Miu Audio MKTP-2
Spectacular audio performance which a open sounding with good separation. Do not be deceive by the look of this little tube amp. You will not believe it is SO POWERFUL that will Blown You Away ! Easily can drive speaker the like of Dynaudio which has 84DB and is Fun to play!
  • TA2024 Tripath Class T Amp
  • 2*15W output power
  • Tube* use – 6922EH (Electro Harmonix Russia Tube)
  • Can use as tube integrated amplifier/PreAmp/PowerAmp and it has headphone amp
  • Front panel jacks for headphones and iPod/iPhone/MP3 input, rear panel connection for line level input
  • An ideal match for quality loudspeakers with efficiencies of 84-88 dB or more
  • Very mini in size – Only 65mm x 60mm x 98mm
Selling at $260 (with 6922 EH tube)
Currently available in Black / Orange / Silver-Blue
Miu Audio MKTP-2 MKII
Spectacular audio performance which give warm sweet, silky sound throughout the mid and high frequencies. Do not be deceive by the look of this little tube amp. You will not believe it is SO SO POWERFUL that will Blown You Away ! Easily can drive a speaker like Dynaudio which has 84DB and Fun to play !
  • TPA3106D2 Class D Amp
  • 2*25W output power
  • With Gold plated speaker binding pole
  • High Power an ideal match for for wide variety of quality loudspeakers
Selling at $295 (with 6922 EH tube)
Currently available in Black / Orange / Silver-Blue / Gold
Miu Audio MKUP-2 – Hybrid 6922 Tube Amplifier 2*25W with MM Phono (New Arrival)
Tube integrated amplifier with Phono preamplifier. The tube preamplifier section is completely separate from the power amplifier section, Phono preamplifier MM—1 input Line and 1 input Phono. Chassis slightly bigger then MKTP2
- TPA3106D2 Class D Amp
- 25wpc + 25wpc @ 4 Ohms, 18wpc + 18wpc @ 6 Ohms, • 12wpc + 12wpc @ 8 Ohms.
- Front panel jacks for headphones and iPod/iPhoneMP3 inputs, input to line level input.l Selector Line/Phono.
- Rear panel connections for LINE input, PHONO input and speaker outputs
- High power allows for use with a wide variety of quality loudspeakers
- Spectacular audio performance!
- Very compact in size – only 75mm x 70mm x 110mm.
Selling at $399
Currently available in Orange
Edited by littlemart
AIBBC TA-100 - Tubes Sabre 9018 DAC/Pre-amp/headphone amp/Bluetooth 4.0 (new arrival)
TA-100 is a very complete ES9018S advanced decoder with XMOS (U8) + Headphone Amp + Bluetooth 4.0 (CSR BC8670) + Preamp Output. Having the highest level of decoding with built-in XMOS USB (U8) to support DSD hardware solution, using high end grade ops amp on amplifying circuit, the latest Bluetooth 4.0 CSR BC8670 programs to support lossless transmission APTX (I2S input receiving a digital signal decoding after ESS9018 preamp output) and a unique patented technology on tube hybrid system with full discrete between the core elements and the pre-amplifier circuit output.
TA-100 (Standard version) is using IPF MUSES8820 + IV MUSE8920 ops amp and pairing with Psvane 12AT7
TA-100 (Premium version) is using IPF MUSES8820 + IV MUSE8920 ops amp and pairing with Psvane (贵族之声T系列典藏版) 12AT7-TII gold tubes
Function:
- DAC chip ES9018S, having 32BIT HyperstreamTM DAC patent structure, and the time domain jitter removal, as well as having a 135dB
dynamic range and distortion of -120dB, the industry's highest level of performance for today. TA-100 has fully utilize the function of this chip,
to satisfy the most demanding audiophiles.
- COAXIAL input straight into ES9018S decoding, support for external high quality digital audio.
- USB digital interface XMOS (U8) with the industry's highest level of 32BIT / 384KHZ ES9018S DAC decoder IC design, support DSD
hardware solution, XMOS U8 decode the benefits of integration and DAC built-in USB digital interface is the shortest distance to get the best
transmission sound quality.
- The machine supports Bluetooth playback, with the highest levels of CSR8670 audio-specific Bluetooth chip, CSR8670 is the industry
supports digital output of a high-quality 4.0 Bluetooth chip, the signal straight into ES9018S decoding, and support for APTX lossless
transmission, powerful, excellent sound quality.
- Input Select: CD / AUX / BT / USB / COAXIAL five audio input selections.
- Output options: Headphone output / can control volume preamp outputs (balanced and unbalanced RCA outputs).
- Fully discrete power amplifier configuration of high-fidelity headphone amplifier design, strong thrust, rear gain switch, 8-1000Ω impedance
completely adapted.
Selling at $499 (standard version), $599 (premium version )
