littlemart
Headphone and Headphone Stands
Real Wood
Note: The stand are carved directly from the real wood and the nature of the wood may not be perfectly line as well as the colour tone will be different from the picture and from stand to stand. Some patch works may have been perform by the supplier. The stand not for fussy or perfectionist buyers. Honestly I see the natural flaw of the wood a much more like a real wood with ‘artistic’ feel. You may not want to have something is too perfect either.
Royal Glam – Handmade Solid Wood Stand
Tired of seeing too many Omega type of wood stand selling in market and with varies pricing? Worried your expensive headphone band will stretch while placing on top of it over the time? No real solid wood feel and smell but only the veneer feel
Royal Glam Handmade Real Solid Wood Stand Carved from solid black walnut and applied lays of Germany OSMO to wax the wood. The WoodLab Royal Glam stand puts your headphones on full display while eliminating cable clutter on your desk. Narrower than the human head even at its widest point, the whale-shaped design allows your cans to rest snugly without adding extra tension— so the headband won’t stretch out over time. It’s large and sturdy enough to fit virtually all models, but maintains a relatively small footprint. Choose the classic all-walnut version, or opt for a contrasting stripe of ash.
Specs:
– Come in Black walnut and Black Walnut with ash
– Dimensions: 4.7 x 3 x 10.2 in (12 x 7.5 x 26 cm)
– Footprint: 4.7 x 2.9 in (12 x 7.4 cm)
– Curve at widest point: 4.4 in (11.2 cm)
– Curve at narrowest point: 1.2 in (3 cm)
– Weight: 1.9 lb (0.9 kg)
Selling @$99 $55/pcs (Introduction Promotion. While Stock last). (Come with no box).
I can give further discount for buying 3 pcs and above . You will not be able to see this price again once this batch is finish. Now even selling much cheaper then MASS DROP
Real Wood Headphone stand - Hook Type
Handmade using solid black walnut wood (you can smell the wood smell when place beside you). Beside can use for hang headphone, it can also be use for hanging accessories. Classic and Elegant looking.
Plain wood base, allow user to do their own craving/drawing to make the stand more personal.
Material : Black walnut / Red Oak (no stock)
Finish: Biotherm wood wax
Note : Simple assembly
Size : Height 27.5CM ( including base ), Stick length 12cm, Base Diameter 11cm
Weight: 180g
Selling $36/pcs
Real Wood Headphone stand - T Type
Hand Made using solid wood(you can smell the wood smell when place beside you). Beside can use for hang headphone, it can also be use for hanging accessories. Classic and Elegant looking.
Note : No assembly is require
Size: height 26.7cm ( including base ), Stick length 19cm, Base 20cm
Weight: 330g
Selling $40/pcs
Edited by littlemart
Aluminum Head Phone Stand
Copper Colour - Single 1
Handcrafted sand and oxidation treatment. Aluminum Material.
Size : 29cm(H), Base 12cm
Selling at $30
Currently available in Black / Coffee / Silver / Gold / Blue / Pink
Copper Colour - Single 4
Size : 25cm(H) X 12cm(W), thickness 4mm, depth 8cm
Selling at $40 - Currently available in Black / Coffee / Silver / Gold / Blue
Copper Colour - Single 6
Height 28cm
Selling at $40 - Currently available in Black / Brown / Silver / Gold
Copper Colour - Single 8
Height 23.5cm
Selling at $25 - Currently available in Black / Brown / Silver / Gold
Copper Colour - Single 9
Size : 26cm(H) X 16cm(L), Base 11.7cm
Selling at $40
Headphone
SoundTech MC2 Headphone
This is new kidz in the block to compete with already establish brands in the market. However you will never know there are always some decent brand start to establish especially this MC2 a very popular model in Mainland online store and has good review.
High Performance, built and important value for money. Seldom see a headphone made with real wood at this price tag. MC2 is a great sense of music headphones , very balanced and accurate sound warm thick lip.
MC2 earphone’s housing made using Argentina Green sandalwood , very simple classical flavor and texture . Argentina Green sandalwood texture clear looking, natural permanent smell. When you listen MC2 , you can feel a touch of sandalwood taste MC2 wooden arena retains the natural texture of wood , only doing polishing process without the use of any paint. Green sandalwood slow growth rate , every piece of timber more than a hundred years of age to become useful. Green sandalwood also known as incense , located in South America and is Argentina best quality green sandalwood.
MC2 first beam using the German first layer of small yellow hand-stitched leather , rugged yet refined . Very mature calm feeling .
MC2 weighs only 180 grams , earmuffs very soft , extremely comfortable to wear , no problem on prolonged listening
MC2 custom 4N OFC headphone cable and gold -plated thickness 6.35 Adaptor .
MC2 supporting two different thickness of the sponge cover ear sound as trimming purposes .
– Thick sponge cover loose atmosphere low frequency , high frequency extension slender. More lively and assertive sound .
– Thin sponge cover strong and powerful low-frequency , IF thick Run Naiting . Sound more feminine restrained .
According to your personal preferences and the front-end equipment to go with the sense of hearing.
MC2 impedance of 32 ohm , sensitivity of 96dB, extremely easy to drive and work well with mobile phone.
Specification:
Impedance : 32 ohm
Sensitivity : 96dB
Frequency response : 16Hz-22KHz
Unit Diameter : 40mm
Headphones Weight : 165g
Cable length : 1.5m
Headphone plug : 3.5 & 6.35mm
Packing size : 260X240X70mm
Package weight : 800g
Accessories: * 2 headset sponge , sponge pads * 2, 6.35 adapter .
Selling @$179 /each
Review:
