kangcore 0 Report post Posted November 4, 2015 (edited) Selling a pair of used ESI Audio nEar04 Monitor Speakers. M-Audio used ESI audio as their OEM for the early generation of their monitor speakers, so these guys have some pedigree. This pair is used, and has been serviced a couple years ago at C.A.N. Audio, to repair a faulty crossover. Otherwise, these speakers have put in several years of faithful, faultless service in a clean, smoke-free bedroom studio. Signature is clear and firm, though on the warmer end of the spectrum, so if you're using these for mixing, do compensate a bit or else mixes may end up a bit bright. Highly recommended as bookshelf speakers for a beginner hifi setup. These speakers simply love jazz and classical music, and will pump out lush, warm audio. These speakers are self powered, so there's no need for an additional power amplifier. They take audio from two 1/4" mono inputs. No XLR or RCA, but if you're thinking of running audio from your turntable to these speakers, you can easily pick up RCA-1/4" mono converters at your neighbourhood DIY store. Comes with power cable, and link cable to connect the two speakers only. NO AUDIO INTERCONNECT PROVIDED. Have installed adhesive rubber feet on the bottom to provide some simple acoustic isolation. Should be easily removed with no permanent damage. Asking S$200 FIRM. PM to deal, or for enquiries. Photos available here: https://carousell.com/p/32984192/ Deal at vivo city duing weekday lunchtime, orchard/somerset in evenings. Bukit Timah / Clementi on weekends. Lowballers will be ignored. Thanks! Edited November 4, 2015 by kangcore Share this post Link to post Share on other sites
