bpribadi
WTS: Mytek Stereo192-DSD DAC - Black Preamp Version
Selling: Mytek Stereo192-DSD DAC - Black Preamp Version.
Condition: Used, very good working condition, never has any fault.
SOLD
Complete with original box and accessories.
Receipt will be provided.
Website:
https://mytekdigital...reo-192dsd-dac/
Manual:
http://mytekdigital....anual_v.2.0.pdf
Reviews:
http://www.audiostre...QCcdyPHQBAcP.97
http://www.6moons.co...ws/mytek/1.html
http://www.head-fi.o...mplifier-thread
Bought new in 2013 from Liveacoustic Singapore (Robert Lai) for S$ 1900 (receipt will be provided).
Very good working condition, clean RCA terminals (always protected with dust caps). No fault record, never been repaired.
Firmware version 1.8.1.
Reason for selling: Under utilized as I have other desktop DACs.
Specification:
- Conversion: 32bit, PCM up to 192k, 64xDSD, 128xDSD.
- Dynamic Range: 128dB (ESS Sabre chipset in 8 mono to 2 stereo config.) THD DAC: -110dB.
- Digital Audio Inputs: SPDIF, AES/EBU, Toslink all up to 192k single wire.
- Clock: Internal Clock Generator (10ps jitter,) Wordclock In and Out, or sync to incoming digital audio input with low jitter JET ™ PLL.
- Internal Async Hardware Upsampling- 16bit 44.1k etc. can be optionally upsampled prior to conversion to 192k/24bit with clock jitter eliminated.
- Transparent, 1dB stepped programmable analog attenuator, separate for main out and headphones.
- Relay bypass of the attenuator for direct purist DAC out.
- A pair of unbalanced RCA analog ins for preamp functions (assignable to volume control) (In Preamp Version).
- High Current, High Slew Rate ultra low distortion 500mA hi-fi headphone amp.
- Worldwide user switchable linear power supply.
- Online downloadable firmware updates.
- Ability of converting standard digital audio inputs into computer FW/USB input.
- Optional infrared remote (Apple Remote Control).
- Enclosure: Compact portable 1/2 rack space 1.72in H x 8.5in W x 8.5in D.
- Weight 6 lbs.
Features Highlights:
Very comprehensive volume control: analog, digital, and bypass.
Analog volume control is not using the conventional carbon track potentiometer that often causing channel imbalance between left and right channels, but using advanced and highly accurate digitally controlled analog electronic circuit (1 dB stepped).
In Analog mode, there are 2 sets of analog volume control to set the line output and headphone volume independently.
Bypass mode to bypass the DAC output directly to line output, bypassing all the volume control. Headphone output is still controlled by the analog volume fader.
About the volume control from Mytek manual:
Analog - The output level is controlled by a programmable analog
fader. This also allows independent level control of the main output
or headphone output.
Digital - The output level is controlled digitally with ultra precision
32bit digital attenuator. This choice does not allow for independent
level control of the main and headphone outputs. Digital fader
measures well, but most users prefer the sound of analog fader.
Bypass - Relay bypass of all faders for the cleanest output path
possible. Only the main outputs are affected while the headphone
output is still controlled by analog fader.
A pair of Analog inputs to make use of the sophisticated analog volume control, and make the Mytek Stereo192-DSD function as Pre-Amplifier for analog sources.
Compatible to Apple remote control.
Those who are interested please email or sms me at:
bpribadi@yahoo.com
967zero 161zero
Self collection at around Simei MRT, or other green line MRT stations by appointment.
Pictures of the real item:
Edited by bpribadi
