red_ryder 0 Report post Posted January 16, 2004 (edited) Hope this post don't offend any audiophiles, but I really don't have the budget to upgrade my player or buy a headamp. Currently using a DVD player as source, connected to a Yamaha AV receiver. Bought a Beyer DT931 from Mackie, but it sounds quite harsh and bright to my ears. On the advice of SGH members, I subjected it to 4 weeks of burn-in. I have also received suggestions along the lines of using better interconnects (currently using optical out), getting a proper CD player, and getting a headamp to smooth out the sound and make it warmer. As mentioned earlier, all these are out of my consideration. So are there headphones out there (<$250) that sound good even with my kind of equipment? By good I mean a warm and rich sounding quality. I like the amount of detail that the DT931 gives, but it still sounds very bright. Edited January 16, 2004 by red_ryder Share this post Link to post Share on other sites
Blues 0 Report post Posted January 16, 2004 warm and rich? for that budget, Beyerdynamic DT250-80/250 comes to mind. It's slightly dark and will not ruthlessly reveal all the harshness, unlike the dt931. But you should try it first at your system, if possible. Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted January 16, 2004 My setup without the amp is also very harsh. Get the amp first.... Share this post Link to post Share on other sites
bwtay 0 Report post Posted January 16, 2004 You are definitely gonna need an amp if you want good sound. However if you are budget constricted, I suggest you go for Grado/Allesandro Headphones. These phones haf relatively low impedance which makes them very easy to drive. I personally recommend going for Allesandro MS1 or a Grado SR80. I own an SR80 and I find the sound quality to be pretty good with even a PCDP. Share this post Link to post Share on other sites
red_ryder 0 Report post Posted January 16, 2004 Heard that Grados are meant for Rock Music? My musical tastes lean more towards Jazz, Classical and pop ballads. Share this post Link to post Share on other sites
Mackie 0 Report post Posted January 16, 2004 Before purchasing a new pair of cans, I suggest U get hold of a pair of Klotz GY107 interconnects and listen to your music via dvdp+AV amp setup via the analogue route ie. bypass the optical connection. I believe whatever harshness and brightness will be significantly reduced. Sonic signatures of the Klotz should suit your taste as I see it. Even a new 1m pair costs <$46 and if it doesn't help rectify your problem, U can easily dispose of it for it's so well demanded. I reckon this is a cheaper solution than buying new cans. Share this post Link to post Share on other sites
Sipher 0 Report post Posted January 16, 2004 (edited) Klotz GY107 + Neutrik Profi RCA connectors are available at LHS @ SLT Edit: some spelling errors Edited January 16, 2004 by Sipher Share this post Link to post Share on other sites
red_ryder 0 Report post Posted January 16, 2004 Before purchasing a new pair of cans, I suggest U get hold of a pair of Klotz GY107 interconnects and listen to your music via dvdp+AV amp setup via the analogue route ie. bypass the optical connection. I believe whatever harshness and brightness will be significantly reduced. Sonic signatures of the Klotz should suit your taste as I see it. Even a new 1m pair costs <$46 and if it doesn't help rectify your problem, U can easily dispose of it for it's so well demanded. I reckon this is a cheaper solution than buying new cans. Didn't realise that there was demand for such things as interconnects?? I was hesitant to buy the interconnects because afraid that there wouldn't be any improvement and end up wasting money. Was actually considering selling off the DT931s and buying a more forgiving headphone instead. thanks for the advice guys, I'll think about it. Share this post Link to post Share on other sites
bwtay 0 Report post Posted January 16, 2004 interconnects actually make a diff....may not be a huge one but definitely noticeable. And by the way, the Grados do sound gd with Jazz and classical music. however they may sound a little bright. Share this post Link to post Share on other sites
Sipher 0 Report post Posted January 17, 2004 try out Mackie's suggest first since it dont really cost much and then decide whether or not to sell off the dt931. Share this post Link to post Share on other sites
N@Z 0 Report post Posted January 19, 2004 Heard that Grados are meant for Rock Music? My musical tastes lean more towards Jazz, Classical and pop ballads. Sounds like a contender for the AKG K501 to me! But these babies need an amp to sound good. Sell the DT931 add that to the cost for the headphone amp even if it is just a CMOY from tropicalrips. I heard the blue metal cased CMOY & I liked it even with the DT250 (250 ohms) & hooked up to a PCDP. Share this post Link to post Share on other sites
