jasonhanjk 0 Report post Posted June 2, 2004 NJM4556AD is good because it has better phase shift than OPA2134PA. Will do further eval when board finish this weekend. Cost for 4556 about $2.00. Share this post Link to post Share on other sites
digi01 0 Report post Posted June 2, 2004 Thanks Digi 01. I may not use Protel as I am more use to eagle. By the way, please comment when the PCB design is out. Had seen your masterpiece... this is my standard comy PCB layout.use 2 opa134 single opamps.ALPS vol mount on boards.wish can give you some ideas Share this post Link to post Share on other sites
digi01 0 Report post Posted June 2, 2004 if remove the volume pot.the PCB boards size is 37mmx37mm,very minize.I have design a sub-boards for CHA47 hook up. hearty cheers~ Share this post Link to post Share on other sites
Absolute0 0 Report post Posted June 2, 2004 Sounds remarkably fun, but I don't really want to get my hands "dirty", and I don't have a need for a portable amp. Nevertheless, have fun, guys! Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted June 2, 2004 Nice. Here's mine: Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted June 2, 2004 Board. Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted June 2, 2004 Component only: Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted June 2, 2004 PCB routing. Too bad only one jumper in red. Try to get 0 next time. 61mm lenght and 79mm width. Is this good Tropical? Or you want smaller? TLE cost $3 so might as well use opamp as virtual ground. Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted June 2, 2004 i think we can leave out the rail-spilter and use 2 resistors, can the rail-spilter be optional with the mounting already on the PCB? if we want to the PCB to be smaller , the op-amps need to be side by side, but i think that will leave it with at least 1 or 2 jumper wires for power cause the power pins on the op-amps will be crossing each other i'll do a mock-up of the side by side layout to see what has to be done Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted June 2, 2004 Ok, new one. I don't really like the 2 resistor as it will fail most of the time. The config will be 3x2 opamp, left, right and ground. Now the PCB is 1.8" x 2.85", about 46mm x 72mm. Mock up?? By the way, what pot you want to use? Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted June 2, 2004 4 jumpers. Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted June 2, 2004 3x2 op-amps...left,right and ground... ...meta42... i like where this is going the board layout looks good, if using L/R/G with 3 op-amps, then will the op-amps still be dual or single channel? the jumpers are for the power rite can try with the op-amps turn 90' this will make the board tighter/smaller for the pot, if we going to use a small one, then the mini Alps will be good, its also easier to get then the panasonic pots. Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted June 2, 2004 Something like that... It is dual opamp per channel. One for amplification and the other for buffer. Err, something like Pimeta and A47 combination. Yes, jumper for power. If you want a tighter board I can remove another 2 cap. Can tell me the board size that you want so that it can fit into a casing. Can have the serial number for pot asap so I can finish design by this weekend.... Thanks... Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted June 2, 2004 for the pot i hav the Farnell no. 919-287-1 but there's 2 versions of the mini alps, one 1 vertical mount, the other horizontal Alps part no. will hav to check... i prefer 4 caps but i don't think this board will fit into any of my cases, but it will make a good desktop amp Share this post Link to post Share on other sites
