bpribadi
The Black Amp
Based on PPA 1.0 circuit diagram, with OPA637 and one BUF634 per channel.
The Front Side
The Back Side
The Board without the Panasonic FC Capacitors
The Tracks
The Inside
Panasonic FC
The Blue ALPS * The Modded Neutrik Socket * The Buffer With Heatsink
My Fav Blue LED
Edited by bpribadi
Yes Digi, one BUF634 for the ground channel. I think any headphone (except AKG K1000, they are ear speaker anyway, not headphone) will not need more than 100mA per channel, so the 250mA from the BUF634 should be sufficient.
Did you guys had any problem with the pictures? I heard photobucket has network problem no.gif
Edited by bpribadi
A job like this can only mean that u had a lot of pre-planning done.
My question though is what does it run on? Batteries or dc supply?
Well done and cheers mate.
Wow! Really neat eventhough u had very tight spacing! Great job!
And the all important question...how does it sound?
Thanks!
You are right, the planning took more time than the actual assembling job wink.gif
I set the voltage at + & - 7.2 volts regulated. Means, can use normal 15 volts adapter which normally gives output at around 18 volts (unregulated), or 2x 9volts battery.
It sounds very good to my ears, my brother like it also. I will cover more of how it sounds later. So far had been burnt in for around 7 hours.
Bram, AWESOME. I have been working on a pimeta, at first I tried to do what you did but it was hard to get the wire to stay flat when soldering it and I gave up and use another type of perf board. You clamped the wire down while soldering? I really like the case, where did you get it?
Wow, hope I have a chance to audition it before you sent it to your brother. happy.gif
Man, you are good.
Those are mini inputs and outputs if I am not mistaken. They look really cool against the black enclosure.
Btw, did you get the PPA board from tangent? Isn't there a newer version?
Thanks Heady!
I use visegrip to grip the cooper wire flat. The cooper wire will expand when heated, so sometime make it difficult to put them nicely. Vicegrip helps a lot. You can borrow it from me, I'm not using it at the moment.
The casing is Hammond 1455N1201, I bought it from Farnell-Newark. They are Newark item, so they charge it in USD, it cost me SGD 41.- (w/ GST). I feel it is so expensive, but my brother likes it.
I also hope that I can try it longer, but my brother brought it to Jkt already huh.gif , so I only tested it for a while. But the so far the OPA637 sounds very good with RS-1. My brother will connect it with Sony XA7 CDP and Grado RS-1, and he will share his impression. Waiting for it happy.gif
Anyway, it doesn't sound much different than my Pimeta, for the OPA637 being very neutral with the right level of treble, and the AD8066 feels a tad more 'airy' with a tad brighter treble.
Thanks Absolute0!
I didn't buy the PPA board. The newest so far is version 1.1, the different is only in the jfet cascode class a biasing of the op-amp. The version 1 is fixed to 1 mA, the 1.1 is adjustable.
Beside that the power supply also different. But here I'm using my own circuit for the power supply, using LM2941 regulator.
Edited by bpribadi
Bram, I was hunting for a nice casing for my second pimeta (ambitious ah, not finish first one which I am trying to fit into sweet tin) in SLT but found only low quality and frankly ugly ones only. Wow the cost of the Hammond is "ouch"!! Our hobby is expensive. wacko.gif
Well done!
The other important question is how much will you charge to have one built? wink.gif
nice board as well.. where you got it..
I bought it in Indonesia about 8 years ago biggrin.gif It is some left over from my University project wink.gif I think it is gold plated, because of the durability, still very clean and shiny, no stain at all after 8 years in storage. Normal copper will not last that well. I think I saw similar board in SLT, forget where...
All are estimated price in S$:
110 for 2x OPA637 & 3x BUF634
40 for Hammond box
20 for the blue ALPS
10 for the Neutrik socket (haven't include the S$2.5 fake neutrik that I bought to mod the spring)
With other stuff like the resistors, Panasonic FCs, connectors, mini sockets, switch, cable, etc. It cost around S$250.- parts only. But it matches amps with price 3x or more it's price wink.gif So still worth tongue.gif
