Kippei
Tubes amp
Time to start a new thread as the old one is quite irrevelant
SOHA: http://headwize.com/ubb/showpage.php?fnum=3&tid=5896
MHHA: http://headwize.com/ubb/showpage.php?fnum=3&tid=5896
YAHA: http://headwize.com/ubb/showpage.php?fnum=3&tid=5771
Orginal thread: http://www.sgheadphones.net/index.php?showtopic=3979
Edited by Kippei
erm how much?
5 bux or so maybe
cant remember
EDIT: this kinda trafo can be easily bought in SLT
the thing is, are u on holiday? then tomorrow can go get
tonight go fix up some of the parts first, PSU parts for example. go go go!
Edited by squalle
erm how much?
5 bux or so maybe
cant remember
Nope not on holiday... Since my part are already premium. Muse , FC, Nich caps + Blue alps (fake), might as well use a high end trafo
socket u go get either from well audio or koba
farnell? within these coming 3 days ( stated to be 4-6 days)
high end trafo? hmm get even more expensive one then, a torroidal! hahaa (here: http://sg.farnell.com/jsp/endecaSearch/par...SKU=4334267&N=0 S$25.81)
but again, there's no point getting high end trafo.
May some1 enlighten me in wat high end trafo provides?
if EM waves leakage, mine has no problem at all. clean signal at the output smile.gif
Edited by squalle
Not sure. Hi end trafo efficiency increase?? low heat? Anyway the dallang trafo look much neater. Now i am stuck with the 7 pin socket...
Millet in the future??
Edited by Kippei
7pin socket, if you've got it off koba, I think you can just swap. try to ask
why keep stock when you're not sure about whether you're going to use it in the future smile.gif
comparison of millet and SOHA is still not out yet. darn
for op-amp supply: LM317 and LM337 hence I've got dual supply
for heater: use LM337, well LM317 will do too if you know where to modify (just reverse the diodes (the two 1N4002))
not really sure why they chose 337 (negative supply instead of positive, just a heater anyway)
show off to you guys.. i got this at $17 include shipping..wakakakakaka
12-0, 12-0 50W from china (MIC la!)
