huangyong 0 Report post Posted January 2, 2006 squalle, suggest a mod, use LM317 + 4.7ohm as CCS to feed the filament. Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 2, 2006 I am trying to fit the circuit in this casing http://sg.farnell.com/jsp/endecaSearch/par...SKU=4273035&N=0 Share this post Link to post Share on other sites
huangyong 0 Report post Posted January 2, 2006 found this: TOROIDS vs. E-CORES ADVANTAGES Toroids: More compact than E-core design Materials cost is lower due to single component Tighter magnetic coupling - lower stray flux leakage E-cores: Easier to automate winding process Can be mounted by pins on the bobbins Easier to isolate electrically multiple windings Core can be easily gapped to extend energy storage capability stuff to read, it will burn your night!! http://www.epanorama.net/documents/compone...ansformers.html Share this post Link to post Share on other sites
huangyong 0 Report post Posted January 2, 2006 experts from DIYaudio said this: http://www.diyaudio.com/forums/showthread....0127&highlight= Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 2, 2006 Where to buy cheap interconnect? Share this post Link to post Share on other sites
squalle 0 Report post Posted January 2, 2006 why the 4.7ohm? oh kippei: my board cant fit into that board, but I think you'd be able to fit urs into that case. I've spaced out too much in my worries abt stray EM waves Share this post Link to post Share on other sites
squalle 0 Report post Posted January 2, 2006 hmm reading from the DIYaudio forum, hence I conclude there's no need to craze all over torroidal the only drawback of EI type trafo is just the leakage flux, which can be dealt with simply by building EM cage around it, cheap and simple Share this post Link to post Share on other sites
huangyong 0 Report post Posted January 2, 2006 sorry, it should be 4.1ohm. some claims that CCS fed to the filament will gives better sound, but my experince tell me that it will give you quieter and darker backgound when no music playback. using LM317, the voltage across 'out" and "adj" should be 1.25V, put a resistor across them and you will have your Constant Current source. the tube needs around 300mA if I am not wrong, so 1.25 divided by 4.1ohm you should get 300mA. Share this post Link to post Share on other sites
squalle 0 Report post Posted January 2, 2006 hmm u sure it needs 300mA? those guys at headwize put the filament as 150mA quote off the headwize forum: "Since the tube is a 12AU7 (12.6V/150mA)" Share this post Link to post Share on other sites
huangyong 0 Report post Posted January 2, 2006 since you guys are building amp, anyone wants to try this.. some cheap mod, good for EI. DaBlock http://diyparadise.com/dablok.html Share this post Link to post Share on other sites
huangyong 0 Report post Posted January 2, 2006 aiya.. forgot u r using 12au7, always tot original SOHA ecc88. Share this post Link to post Share on other sites
squalle 0 Report post Posted January 2, 2006 since you guys are building amp, anyone wants to try this.. some cheap mod, good for EI. DaBlock http://diyparadise.com/dablok.html maybe I'll try that all parts easily obtainable Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 2, 2006 Holy sh*t.... putting stuff on live Share this post Link to post Share on other sites
kross 0 Report post Posted January 3, 2006 wa...only a few days and suddenly like so many people building amps. anyway, after breadborading the amp, i decided to solder it onto the stripboard but something happened, and it didn't work. dunno whether i overheated the transistors or the tube or wat. anyone knows how to check whether the transistors are working or not? Share this post Link to post Share on other sites
