cmk 0 Report post Posted May 22, 2006 I just received a new PA2V2 from Gary, arrived in a nicely packaged small bubble wrap envelope, incredibly small. Went and got myself one of those multivoltage adaptors and plugged in the power supply, was fortunate to have plugged in the negative tip correctly and powered up the unit. It works fine and sounds, Large, shall we say. Much bigger than the size of the unit itself. Now I was wondering about those of you who own one, does it sound better with the AC plugged in, or better battery powered? I'll go home tonite and try out myself, but just wanted to find out others' opinion. Share this post Link to post Share on other sites
aaron-xp 0 Report post Posted May 22, 2006 (edited) How much you did you get it for? Edited May 22, 2006 by aaron-xp Share this post Link to post Share on other sites
cmk 0 Report post Posted May 22, 2006 Cost is US$56 w/o the adaptor. Share this post Link to post Share on other sites
aaron-xp 0 Report post Posted May 22, 2006 Thanks. May have to DIY a CMOY if I want an amp. No money. Share this post Link to post Share on other sites
cmk 0 Report post Posted May 22, 2006 Ok question answered, quite obvious actually. Share this post Link to post Share on other sites
aegisofrime 0 Report post Posted May 22, 2006 cmk what do you think of it? My friend just got his recently, and he was kind enough to lend it to me for 2 days. While there was a slight improvment in sound, it was a bit too slight for me to spend $56. Gary's service is excellent though. Share this post Link to post Share on other sites
cmk 0 Report post Posted May 22, 2006 (edited) I think this is a bit system dependent. I'm using it with the MS Pros on my iRiver IP400 and it sounds v good. The soundstage expands quite a bit and the music has more body. So far only complaint is that it doesn't extend very deep into the bass, but I'm splitting hairs here and comparing it with my home rig. For a mobile amp, its great. I'll need more time to try it out on my other cans, but so far so good. The mids are especially nice. The sound appears to be tilted to the right channel, mmm... not so good here. The MS Pros are balanced to w/i 0.5db for both channels, so it can't be the cans. I'm beginning to suspect the cheap mini-mini cable. It could be just a thing with running-in, its fine on another song. The highs are quite crisp, v nice. I'll report back when I've spent more time playing around with this cute thing. On another vocal piece its seems to be fine, vocals are centered, but the lower mids are a bit too full, giving a rounded presentation, and consequently the image is blurred. Again, here this is in comparison with the home rig. As a portable amp, I think it does everything asked of it quite well. Edited May 22, 2006 by cmk Share this post Link to post Share on other sites
afbug 0 Report post Posted May 22, 2006 I own one but i never tried it on an AC adaptor before. So can't answer your question. But its better to use a better IC. The supplied ones are not so good. Limits the bass and can sound a bit congested. Share this post Link to post Share on other sites
positive 0 Report post Posted May 22, 2006 Hi. I ordered from gary the amp too. May i know roughly how long b4 it reach our shore?? Share this post Link to post Share on other sites
kanga 0 Report post Posted May 22, 2006 i faced the similar problem of the sound tilted to one side too... but gary advised me to get a line-in attenuator because the problem only occurs at low volumes. with the attenuator lowering the volume, i can turn the knob up and this solves the problem Share this post Link to post Share on other sites
cmk 0 Report post Posted May 23, 2006 afbug/fongalv Any recommendations for a better IC? If I want to choose my cable and/or DIY one, does someone like LHS carry those 1/8" plugs? Ok, I tried out both direct AC and with batteries, its clearly batteries which have lower noise and they sound louder too, don't ask me why. The channel imbalance I hear is despite turning up the vol. I have it at around 2 o'clock and its there on the MS Pro, but its not apparent on any of my other cans. I did try it out with the 990Pro, K501 and 880, all sounded good. Shipping took 10 days exactly. Share this post Link to post Share on other sites
afbug 0 Report post Posted May 23, 2006 I only experience channel imbalance at 1.5 o'clock. 2 and above is fine on the ER4P/UM2. But isn't 2 o'clock really soft? Or did you get Gary to set higher gain? I normally listen at 3-5 o'clock for earphones and 6-7 for headphones. As for batts Vs AC, i guess its got to do with power supply. (Batts/wall supply) Dun use normal alkaline batts too. Recharables works and sounds best. For IC, i'm using a Cardas HPI. Other brands, i got no experience. As for LHS stocking 3.5mm, i think should have. Quite common? Share this post Link to post Share on other sites
tbln 0 Report post Posted May 23, 2006 The supplied mini-mini is functional at best. You can do better with many of the other choices in the market, from DIYs (LHS is a great source) to commercial ones like the Cardas HFI. Given the cost of the PAVV2, I would not go overboard with spending too much on a mini-mini unless you are planning to move up the portable amp ladder soon I have a number of spare mini-minis (from my search for the Holy Grail) that I am looking to sell. PM if you are interested. Share this post Link to post Share on other sites
squalle 0 Report post Posted May 23, 2006 if you want a clean sound out of using wall supply, then the output DC has to be regulated one I've opened some wallwarts (AC-DC adapter, or so they claim). inside there's nothing to regulate and/or to suppress the ripples. so that's why with the higher noise floor I suppose cmk, LHS sells a few types of 1/8" plugs. go there, look around. and pick the one that you think gonna suit ur budget and ur expectation best. LHS, however, does not sell exotic cables. they sell high quality cable at sane prices Share this post Link to post Share on other sites
cmk 0 Report post Posted May 23, 2006 The supplied mini-mini is functional at best. You can do better with many of the other choices in the market, from DIYs (LHS is a great source) to commercial ones like the Cardas HFI. Given the cost of the PAVV2, I would not go overboard with spending too much on a mini-mini unless you are planning to move up the portable amp ladder soon I have a number of spare mini-minis (from my search for the Holy Grail) that I am looking to sell. PM if you are interested. ygpm Share this post Link to post Share on other sites
