Shiro MS08th 0 Report post Posted August 7, 2006 Hi guys, First thing I would like to ask is, is there anyplace that sells HD580 replacement pads, or is there any other brands pads that will fit HD580? Secondly, would like to buy those stuffs that will clean or protect the interconnects or headphones jack from oxidising. I look through the FAQ, only saw progold stuffs and the phillips degreaser. The progold price is abit steep, is there any other brands for it? Or what place that sells phillips degreaser? The phillips counterpart is cheaper and more affordable for me, even though the sacrifice the quality grade. Thanks! Share this post Link to post Share on other sites
heady 0 Report post Posted August 7, 2006 Hi guys, First thing I would like to ask is, is there anyplace that sells HD580 replacement pads, or is there any other brands pads that will fit HD580? Secondly, would like to buy those stuffs that will clean or protect the interconnects or headphones jack from oxidising. I look through the FAQ, only saw progold stuffs and the phillips degreaser. The progold price is abit steep, is there any other brands for it? Or what place that sells phillips degreaser? The phillips counterpart is cheaper and more affordable for me, even though the sacrifice the quality grade. Thanks! Plugs can be cleaned with an eraser (yes, a rubber) and alcohol. RCA plugs, I just connect, remove and re-connect a few times. I don't think there is a need for expensive solutions, unless you want to splurge. Share this post Link to post Share on other sites
Shiro MS08th 0 Report post Posted August 7, 2006 Hi guys, First thing I would like to ask is, is there anyplace that sells HD580 replacement pads, or is there any other brands pads that will fit HD580? Secondly, would like to buy those stuffs that will clean or protect the interconnects or headphones jack from oxidising. I look through the FAQ, only saw progold stuffs and the phillips degreaser. The progold price is abit steep, is there any other brands for it? Or what place that sells phillips degreaser? The phillips counterpart is cheaper and more affordable for me, even though the sacrifice the quality grade. Thanks! Plugs can be cleaned with an eraser (yes, a rubber) and alcohol. RCA plugs, I just connect, remove and re-connect a few times. I don't think there is a need for expensive solutions, unless you want to splurge. Ooh eraser lol! But alcohol, what kind? Can't be using tiger beer and clean it right? Share this post Link to post Share on other sites
heady 0 Report post Posted August 7, 2006 Aiyoh, tiger beer not enough alcohol. You need to buy some methylated spirit and use that instead. An eraser removes the oxide layer which otherwise is hard to remove. Share this post Link to post Share on other sites
gin. 0 Report post Posted August 7, 2006 or also denatured alcohol or isopryl alcohol. something like 91-95% alcohol contect i think, they are easily available at watsons or guardians at $3++ Share this post Link to post Share on other sites
Shiro MS08th 0 Report post Posted August 8, 2006 Thanks heady and gin. Will go alcohol stuffs soon. Yesterday used eraser and rub already. So is after eraser rub then use alcohol with cloth and rub? Share this post Link to post Share on other sites
zhapchit 0 Report post Posted August 15, 2006 Hi guys, First thing I would like to ask is, is there anyplace that sells HD580 replacement pads, or is there any other brands pads that will fit HD580? Thanks! think you can check with Senn asia http://www.sennheiserasia.com/EnquiryForm.aspx?type=G Share this post Link to post Share on other sites
