N@Z
Need help to build
Ok 2 cans of redbull down. Im ready to dive in and find all the bits I need online.
I've got my MSword open. Building my list now. going to www.farnell.com the link fishball gave me. Looks like they have everything i will need.
Order Code (SKU) Description Manufacturer Code Unit Price Quantity Basket
791039 IC-DUAL HIGH SPEED OP-AMP OPA2134PA $5.21
117298 IC-OP AMP DUAL FET INPUT OPA2137PA $3.55
117304 IC-SM OP AMP DUAL FET I/P OPA2137UA $3.55
401298 IC-OP AMP DUAL DIFET LOW NOISE OPA2111KP $36.72
401286 IC-OP AMP DUAL PRECISION OPA2107AP $46.64
looks good anyhow smile.gif thanks Nothern Oak
mad.gif This is f**ked. I dont know what the hell all these bits are or where to find them on this damn useless website mad.gif
Im gonna get help.
My META mint uses the OPA 2132UA OP AMP, what would be the difference? unsure.gif
Wortel:
OPA2134 -> meant for audio use. It would help if you read the first page of the datasheet of the opamp. This way, you wouldn't end up cursing yourself laugh.gif
mat:
OPA2132 is fine as it's almost the same as OPA2134. I've heard that it's harder to make 2132 oscillate than the 2134. BTW, 2132 is no longer in production.
If you're not good at soldering, you may need a spare cause prolong heat on the IC pins will burn the entire circuit. Preferred way is to get those 8 pins socket so that the opamp can sit in it only after you solder the socket.
Should I use a socket? Im still not sure. Is there any advantage to not using them?
ohmy.gifohmy.gif kklah will go to visit d*ck Smith and Tandy tomorrow.
I used to remember in my youngers days, there's the Tandy Radioshack computer.
