skidz 0 Report post Posted March 28, 2007 I bought my sennheiser mx55 just over a month ago. The cable was kinda spiraling abit but didn't bother me much until the rubber began to tear up and exposing the wires. I tried taping them up but soon more tears began to show, its in such a bad state now. Are there shops in Singapore that can fix it? Recabling it or something. Share this post Link to post Share on other sites
Xiao_Catz 0 Report post Posted March 28, 2007 i think its better for u to replace it rather then fixing it or recable it Share this post Link to post Share on other sites
skidz 0 Report post Posted March 28, 2007 Replacing is not an option coz I lost the receipt. Its a good piece of earphones but the cable is a let down. Share this post Link to post Share on other sites
Xiao_Catz 0 Report post Posted March 28, 2007 i think your left with 1 option now thats to replace it Share this post Link to post Share on other sites
skidz 0 Report post Posted March 28, 2007 hmm ok thanks Share this post Link to post Share on other sites
loop_ 0 Report post Posted April 4, 2007 (edited) well, if it's still working fine and you're not too bothered about it looking not as nice I have 2 suggestions 1) buy some heat shrink tubing, use it to cover the exposed wire, and then use a soldering iron to make the tubing shrink to fit. Will look prettier than (2), but requires some diy skill 2) what tape did you use to tape it? Try black electrical tape and tape it. Edited April 4, 2007 by loop_ Share this post Link to post Share on other sites
skidz 0 Report post Posted April 5, 2007 Thanks loop...I was thinking on the shrink tube, but its too hard isn't it? I'm currently using the duct tape now, I'm taping it in a way that it won't easily come out. The shrink tube looked a better solution though. Share this post Link to post Share on other sites
Kube 0 Report post Posted April 5, 2007 I suggest you start finding a new pair. Probability dictates it'll break very soon. Experienced the same problem before... got worse quickly. Share this post Link to post Share on other sites
loop_ 0 Report post Posted April 5, 2007 yea ideally you should get a new one. but if you don't care about looks can save money...yes I think heat shrink tubing would be good, in fact you can use heat shrink and duct tape the ends so it is less likely to move around. but i think the tape is really good enough so long as the wire is in place and is not getting worse. pictures? might shed some light on alternative solutions Share this post Link to post Share on other sites
skidz 0 Report post Posted April 6, 2007 Ok, will try to post a pic later. Not going to be so soon for me to spend another $60 for another pair of earphones. This is the most expensive I've bought and the best so far but if I were to buy a new pair I'd buy this again. Share this post Link to post Share on other sites
frost_ink 0 Report post Posted April 8, 2007 (edited) hi , first sorry skidz, need to borrow your thread as my superfi 3 cables also have the same problem. Hey guys, i was wondering whether the clear cable that is used in super fi 3 can be bought ? Edited April 8, 2007 by frost_ink Share this post Link to post Share on other sites
Stereo_Electronics 0 Report post Posted April 10, 2007 We sell the clear, black and white cable for UE superfi series, you can PM me for further info. Share this post Link to post Share on other sites
frost_ink 0 Report post Posted April 12, 2007 We sell the clear, black and white cable for UE superfi series, you can PM me for further info. I when to your shop to get the black cable 2 days ago, it was a very busy period, not sure whether you remember, anyway thanks for the info Share this post Link to post Share on other sites
alamakazam 0 Report post Posted April 16, 2007 well, if it's still working fine and you're not too bothered about it looking not as nice I have 2 suggestions 1) buy some heat shrink tubing, use it to cover the exposed wire, and then use a soldering iron to make the tubing shrink to fit. Will look prettier than (2), but requires some diy skill 2) what tape did you use to tape it? Try black electrical tape and tape it. actually will soldering impose more noise too it? more resistance? Share this post Link to post Share on other sites
Rowdy 0 Report post Posted November 26, 2007 actually will soldering impose more noise too it? more resistance? I read somewhere that soldering may affect the properties of the conductor close to where you solder due to the high heat. Not very sure on that, but what I did was to use a hairdryer to heat the heat shrink tube, may take a longer time but at least the tube shrinks nicely with no visible marks. I did this with my power cable plugs. You will need a tube just about twice the diameter of your cable so when it shrinks, it becomes a tight fit and won't slide up and down. Share this post Link to post Share on other sites
