unkle11
Laptop to regular amp?
Hi guys noob to PC audio here,
my situation is this, recently i've began to buy songs from itunes as some of the music i listen to are abit obscure and i can't find them in shops here, so i tried connecting my laptop (macbook pro) to the line in of my regular home amplifier, but the sound is horrible, i do realize the bit rate of the mp3 probably effects the sound quality, but is there a way to upscale the sound to almost CD quality? will a headphone amp work for my purposes? or the creative X-Mod seeing as it is also an external soundcard?
sorry if i posted this in the wrong section
thanks in advance :D
The best thing you can do is to improve the quality of your files. Songs off iTunes is pretty crappy. Gotta work on that first. No point amplifying a lousy signal. It makes things worse.
as nofing said, get higher quality mp3s.
then get a gd soundcard, i have the echo audio dj. it's pretty gd, n compact too. 0404 usb is another great choice, but much bulkier
if u can afford the bulk, connect the line out to an amp.
then amp to a gd set of phones.
take into consideration if u want yr system to be stationary or mobile to decide wat components u need.
looks like u have some way to go!
1st - Source is very important. Thus get Cds and rip them in lossless format
2nd- For a laptop, get a dac and amp. You can try the Fubar 3. Its a DAC and Amp together. No worries as the fubar 3 has a usb connector.
