red_ryder 0 Report post Posted October 29, 2007 My Beyer DT931s come with a 1/4" jack, so I connected it to an adapter before plugging into the Firestone Icute amp. There was a lot of static, and the sound was mono. But when using the exact same adapter on the Sennheiser HD-600, it sounded perfectly ok. Why is that so? Now I'm afraid to buy another 1/4" to 1/8" adapter in case the same thing happens again. Anyone has advice? Quote Share this post Link to post Share on other sites
cmk 0 Report post Posted October 29, 2007 Sounds like a contact problem. Quote Share this post Link to post Share on other sites
barqy 0 Report post Posted October 29, 2007 ^ agreed. maybe your DT phones have a problem w/ the 1/4" connector You could always reterminate the 1/4 to 3.5mm If the adapater your using is the same one i have for my hd595, i'd advise against using it too much b/c there is no extra wire for the adapter which puts a lot of strain on your jack Quote Share this post Link to post Share on other sites
icecreamfreak 0 Report post Posted November 4, 2007 If youre planning to get a better adaptor get the grados one its good ! Very tight Quote Share this post Link to post Share on other sites
barqy 0 Report post Posted November 12, 2007 If youre planning to get a better adaptor get the grados one its good ! Very tight true if you have a soldering iron, buy a female 1/4" jack, add some wire inbetween, and terminate to 1/8". Quote Share this post Link to post Share on other sites
mamboman 0 Report post Posted November 18, 2007 My Beyer DT931s come with a 1/4" jack, so I connected it to an adapter before plugging into the Firestone Icute amp. There was a lot of static, and the sound was mono. But when using the exact same adapter on the Sennheiser HD-600, it sounded perfectly ok. Why is that so? Now I'm afraid to buy another 1/4" to 1/8" adapter in case the same thing happens again. Anyone has advice? I purchased both the 1/4 to 1/8 Grado and the Senn adapter. I find the Grado a little longer but much stiffer than the Senn ones. So I prefer the Senn ones. But it is substantially tighter than the Grado ones when I plugged my Beyers into it. Quote Share this post Link to post Share on other sites
