iewgnail
Teflon insulated wire
As above.
Where can i find them? clear tubing
The last time i check with LHS, they dont have it.
Edited by iewgnail
Some audio diyers actually buy silver wire and teflon tubing and then thread the wire through the tubing themselves.
I have seen some silver wire in clear tubing in Bytetron in SLT but don't know if it is teflon.
i want to get either pure silver or copper.
but would like to have a clear teflon tube (self thread) or teflon coated like the one on homegrownaudio.
basically want to make a 3 wire braid for a ipod lod. something like the one ALO made using cryo treated wire.
cosmetically look nice and can make to 'c' shape easily.
Erm..I'm not too sure if I know what you're talking about. But it's teflon coated silver plated copper?
Bytetron was selling pure silver cable in clear insulation. Cost S$17 per foot if I am not wrong. Too rich for my blood. :P
Ahfart Audio sells pure silver and also pure copper wires I think also in teflon but don't know if the teflon is clear.
is it difficult to thread the wire through the tubing?
cheaper to self-thread or cheaper to buy already teflon coated wire?
It's not difficult to thread the wire through, but I would be more worried about the speed of oxidation.
bytetron sells cables from ahf art audio,
however the grade of the teflon is not the best,
there was some shrinkage when exposed to an open flame.
my diy interconnect using the silver cable, sounds very detailed but neutral.
oxidisation is not a issue with pure silver cable,
slinky links pure silver interconnects use air as an insulator
see here <http://www.slinkylinks.net/SlinkylinksCable-3StepProcessAir.htm>
Edited by jenhwa
U can get the clear teflon tubing from Farnell. They sell it in different internal diameters. Can ask the engineer on site to assist you.
If you read in detail under the FAQ section, it states:
"Will air cause corrosion?
Yes, however silver oxides are conductive, and although not as efficient as pure silver, will not be detrimental to sound and Slinkylinks performance."
Copper or silver will oxidise in time except the effects of oxidisation on silver is not as bad as copper but I personally would not want to use a pair of oxidised silver interconnects.
I remembered coming across high grade cables that uses "AIR" as a dielectric but not any type like Slinkylinks but inert air which not only is a excellent dielectric but also for it's non-reactive properties.
Edited by Stereo_Electronics
