PPkiller
D1 opamp.. share ur findings...
D2 seems to be iBasso D1 lite. Purely USB input without the extra input connectors ... coaxial, SPDIF.etc
Edited by WatCult
PPkiller: Check with you.. what is the stock opamp inside your iBasso D1?
Have you tried the LMH6643 as buffer and the LTC6241HV for the L/R?
Mine came with 6234 L/R opamps and 5532 buffers.
I prefer the treble and bass of the OPA2111 for the LR and 6241HV for the mids.
The 8656 sounds really good on the DAC too. Tried it outputted to a Move... very sweet. But definitely not portable
shall we have a little meet to hear the sounds from the D1s that we have? how about mid dec so that there's sufficient burn-in time for the D1s?
Probably chip in a bit with something slightly off topic.
If you are using OPA627, look for Carlosfm's tip on how to decouple the 627s. You can find that at diyhifi.org. I recall having a small decoupling MKP cap between V+ and V- and then decoupling between V+ & Gnd and V- & Gnd. The important thing to note is to keep the wire leads of the caps as close to the 627 pins as possible.
I hear significant differences doing so for the OPA627.
Edited by Northern Oak
guess i'm gonna do a bg mod soon... mamboman and watcult... which phones are you useing with D1?
I am using with the following :
IEMS :
UM1
UM2
E4c
E500PTH
SF3
SF5Pro
TF10Pro
Cans :
DT770/250 2005
DT990/250 2005
AKG K701
MS2
