alvin1118
DIY: AMB Lab Mini3
Received my LM4562MA, removed the AD8397.
OMG, 2 PCB track came out :cry:
got to use tiny little jumper to solder the LM4562MA on the PCB.
Luckily, my Mini3 still works well :grin:
AMB Mini3 with LM4562MA, current rating 15mA, which means 170mAh battery can last about 10hrs :)
It sounds very detailed, a bit too detailed and cause harshness in high..
great for monitoring purposes instead of easy listening :party:
my one side went very soft. suspected somewhere shorted.
anyone wans to help me take a look?
nowadays no time to dig out my soldering kit and inspect the pcb. =x
i guess, this is what i want after research & experiment for so long....
Specification:
1. L&R Channel: LM4562MA
2. Ground Channel: OPA227U
3. Q. Current: 14mA
4. Power Rail Splitter Caps: Panasonic FM 330uf//330uf//330uf per channel
5. Power Supply Reservoir Caps: Panasonic FC&FM 2200uf//470uf
6. OpAmp Decoupling Caps: Wima 0.1uf
IMPRESSIVE! :cans:
Guest jacj6049
IMPRESSIVE indeed!!it's a beauty!!!but where are ya get all those mod parts n op amp?can share wit me?
regards,
Guest jacj6049
hi all,so how many hours need to run in for mini3,jus finished my 1,sounds ok,a bit murky,so do i really need to run in?
regards
Specification:
3. Q. Current: 14mA
IMPRESSIVE! :cans:
Wish U could do the same with mine, not satisfied with my actual Mini3 and hesitate to change to O2 amp!
