Azurath
Recommendation for open cans.
What kind of instrumental music are you referring to?
Symphony? Chamber? New Age?
HD650 is a fine choice if you add/upgrade an amp (sooner or later u will be tempted to do so)
New Age actually. I have a Crossroads Edge Amplifier hidden in my drawer. Would the HD650s do well with it?
HD650s works with amps from S$200 to S$10000.
Only yourself can judge whether you current one is doing well..If you're not sure, AB compare should help.
Guest dragonboy
Stereo had a ready set-up system of the Earmax standard. I think its going below 1K. Good match with the H650.
