palestofwhite 0 Report post Posted October 13, 2008 Hi, I have a pair of ER4P which I use with the Shure MPA Music Phone Adapter to my iPhone. I was thinking of shortening the cable wires of my ER4P to better suit the setup. Is it worth the while shortening the wires? If so where can I do it locally? Thanks. Share this post Link to post Share on other sites
blackmouth0 0 Report post Posted October 13, 2008 use normal wire wrap to shorten? Share this post Link to post Share on other sites
palestofwhite 0 Report post Posted October 13, 2008 Hi blackmouth, I've tried using that but it adds on too much cable clutter. The weight of the MPA Mic plus the excessive cables and transducer is too much to bear for the ER4P's cable clip. Any input guys? Share this post Link to post Share on other sites
wkwlb 0 Report post Posted October 13, 2008 you need a pair of scissors, a replacement 3.5 plug, a soldering iron and some solders. Destruction time! Share this post Link to post Share on other sites
palestofwhite 0 Report post Posted October 13, 2008 Hi, Maybe you could name a shop or place where a professional can do it for me at a good price with the right equipment? Share this post Link to post Share on other sites
heady 0 Report post Posted October 13, 2008 Hi, Maybe you could name a shop or place where a professional can do it for me at a good price with the right equipment? The usual place - LHS, level 2 at Sim Lim Tower. Look for uncle with afro hairdo, sitting outside shop with a pair of soldering irons. Share this post Link to post Share on other sites
palestofwhite 0 Report post Posted October 13, 2008 Hi heady, Thank you very much. Do you know if the type of solder used on the wire will have any effect on the sounding of the earphones? How about the plugs? I was thinking about switching to a straight plug. Share this post Link to post Share on other sites
heady 0 Report post Posted October 13, 2008 I don't have the super ears which can hear small differences and so my opinion is biased. I like using cat5e wire for my amps. Copper sounds good to me. I think solder has very little effect but if using silver wire, should use silver solder. Share this post Link to post Share on other sites
palestofwhite 0 Report post Posted October 13, 2008 Hi heady, Thanks again for sharing your experience. I'm quite paranoid and have no idea what is going to happen to my earphones, but I shall just leave that to the expertise of the fellows at LHS. I'll let you know when I've gotten the wires done up. Cheers. Share this post Link to post Share on other sites
heady 0 Report post Posted October 14, 2008 There is only one "fellow" at LHS who does the soldering outside the shop, his name is Patrick. He may also try to sell you silver interconnect he made himself. I have no experience with the silver interconnect as copper has always been good enough for me. Share this post Link to post Share on other sites
LP12 0 Report post Posted October 22, 2008 At LHS I usually ask for Mr Lim to do my DIY belden cables, his workmanship is superb...sometimes if on the way, he even delivers his cables, makes life easy, you can order your cables just with a phone call. Share this post Link to post Share on other sites
