soundsync
Sennheiser HD800
if you are interested to make, ahfaudio has this wire in various thickness of 0.5mm, 1mm, 1.5mm..
cant remember the exact prices but 0.5mm is somewhere around $17/metre, 1mm is probably 40+/metre and 1.5mm is 70++ per metre.
so if you intend to go double stranded on each side you might need about 6 metres. i would think 1mM is a good diameter.. its not that stiff.. 1.5mm is too thick and stiff
Seems like a risky investment :blink: ...40X6m=$240..HD800 proprietary connectors not included, around USD40/per pair without shipment..and a good SE 1/4" jack, audiophile grade solder and skills(with a good temperature controllable soldering iron. It will not be easy to handle the HD800 connectors soldering as well).. :think: The cable sounds interesting and promising for its bass performance, but I still prefer a readily made cable at the moment..
Aron, APS cable not ready yet before Can Slam? :cans:
i'll be doing one for my hd650, so probably when everything falls into place i'll update on the sound signature of it.
May I know who long did you guys have to wait for your HD800's FR test certificate after you mailed in the warranty card?
Guest crumple_r
does anyone know where to get the HD800 headphone connectors?? =X
I'm pretty sure they were selling it over at Stereo. Btw, any idea how much a local set of the HD800s cost?
