jasonhanjk
Sgheadphones DIY A47 pocket amp kit
Another "bad" thing having a cap in the signal is it will slow down the 20Hz to 100Hz frequency by 10 degrees. Meaning sound is distort a bit and the tempo maybe slow.
cool...thanks for the info Mackie...
So a cap would be a 'bad thing' in the signal path? Does the current design have a cap then?
Hi jason,have you plan to offer a all parts kit?including the case?
Ya. $40 will be a max out version. I had done a calculation using cheap opamp and without pot and casing will be less than $25. Will update first page.
Currently still creating the alps pot symbol in eagle as it is not available. Find some PCB manufacture and will contact them next week.
user posted image
initial test is very promissing, drives Grado without any problem, design a layout also seems to be very stable, don't hear any noise even with an expose board
user posted image
i hav tried a few op-amps for the left/right channels changing out the opa2134 that jason left on the amp, AD823 , LM881 , opa2604 & opa2228.
user posted image
the LM881 was unusable, it has a lot of distortion, and one of the chip heats up, i'm guessing the speed of this op-amp thats causing this.
the AD823 sounds good, with very good drive, but i feels its a little too full-bodied, lossing some details, this chip still sounds better with EL2001 or BUF634 as buffer smile.gif
my fav op-amp with this board is the opa2228, this was very surprising to me as the chip didn't sound good on a Cmoy or A47. The opa2228 sounds the most balanced of the 3 op-amps i tried, with good details and mid-range
the opa2604 sounded weak, i think this chip needs a high voltage to sound good, still trying it out
Edited by tropicalrips
Ooh...you guys are at the final few development stages... i cant wait!
Hi Tropicalrips,
I thought you guys built an A47? So what circuit is good for the OPA2228?
I would like to try one, let us know when you guys ready with the 'production model' yes.gif
tropicalrips,good PCB layout.those components looks balance and neat.I think what you need is a sexy case now laugh.gif
What power supply do you use for? and have you do the high frequency compensate in feed back loops?
I can almost hear it as interest in this project flares up following tropicalrip's post.
uses audio grade components too...
blackgate and WIMA. am i right??
would you guys condsider using opa627 for this amp?
though it's expensive ( $40+ in farnell ), but we have a lobang king here, can get it
for around half price.
maybe we can use opa627-->opa227/228.
Edited by huangyong
Huangyong wrote:
...though it's expensive ( $40+ in farnell ), but we have a lobang king here, can get it for around half price.
Hi Huangyong,
Does your 'lobang' can get the OPA637 as well? If you don't mind, please let us know where to buy OPA627/637 with half of Farnell price biggrin.gif
Thank you so much!
Bram
Edited by bpribadi
