Dictatormax
Beat audio TT-X
"6单元定制耳塞旗舰型号:TT-X集所有定制耳塞优秀之处于一身,拥有强劲的实力,顶级的6单元配置加上Beat audio 独有的Three transmission channel 技术的运用,使得同样的一条塞子,通过更换带有不同交互模块的线材,即可在自己喜欢的音乐风格上发挥到极致!彻底打破高端耳塞声音风格固死的传统僵局!" - Beat Audio
let me loosely translate the above.
"6 drivers flagship custom iem: TT-X amassed all the virtues of the rest of the iems in itself, packed with solid capable, top 6 drivers coupled with Beat audio's proprietary Three transmission channel technology usage, using the same iems, through cables with different crossovers, one can instantly enjoy your very own music style to the max. this totally smash through the conventional way on how top notch custom iems present their music. "
certainly this is a novel way of changing the sound characteristics. i am certainly eager to see the reviews on this one.
at the moment it seems to be available through taobao. pricing varies with different cables. 4500, 5800 and 6600(yuan).
Beat Audio
Edited by Dictatormax
"Three transmission channel概念:简称TT,普通的定制耳塞只能满足某一种听音风格之喜好,而我们的听音风格又是多样的,要把所有风格的塞子都买回来也不现实。
TT-X的概念正是为了满足一塞多种需求而诞生!
TT-X拥有最顶级的豪华配置----12单元设计,无论在何种风格领域都显得得心应手,无比的强大!
3X通道的使用,使得交互传导模块得以应用,从而带来无限种可能,通过更换带有不同交互模块的线材,即可在自己喜欢的音乐风格领域发挥到极致!
无论是,摇滚,古典,流行、、、都可以随意在TT-X这个平台上得到完美!从此不必换塞~!"
translate: Three transmission channels concept: simply known as TT, normally a custom iem can only satisfy with a certain sound signature, but we listen to different music genres, to buy all different iems with different music presentation back is impractical. TT-X concept exactly fulfils the desire of one custom iem- multi use.
TT-X possess the best, luxurious package - 12 drivers design, capable irregardless of any music style or genres, strongely peerless.
Usage of 3X channels, allow the ease of use with different crossovers parts, ushering limitless possiblities, through changing wires with different crossovers, instantly work on one's favorite music genre to the max performance!
irregardless of, rock, classical, pop etc, they will perform perfectly with TT-X! there is no longer a need to change iem ever again!
"属性:使用共12只世界顶级动铁发声单元,融合Beat audio技术研发结晶《3X通道》技术,开创性的让耳塞上带有特殊“3X通道”结构,利用强大的“第3通道”实现多线程交互传导"
translate: Unique features/attribute : uses 12 top notch armature units, match with Beat audio's creation of Three transmission channels technology through researching, pioneering the usage of "Three transmission channels" architecture on custom iems, using powerful "3X channels" to enable multi cables with crossovers in transmission.
"第3通道:普通的耳塞包括普通定制只有两个接触点(或插孔),《Beat audio TT-X》 6单元定制拥有强大的“3X通道”技术,共有3个触点(三个插针口)改写了音频信号传导的传统方式,通过三接口的不同使用方式从本质改变声音风格,达到一劳永逸的定制目的!"
translate: the third channel: normal iems only include the usual 2 connectors(pins), Beat Audio TT-X's 6 drivers custom iem possess powerful "3x channel" technology, there are a total of 3 connectors(3 pins) changing the way sound frequencies are transmitted from the conventional method, through the unique usage of 3 connectors it changes the sound characteristic, attaining the eternal purpose of customizing.
"专业评测:
只有它才拥有造就属于你的天籁的能力,极为宽广、纵深悠远的声场,优秀的解析让你听到什么是“吐气如兰”,清澈而又丰满的中频,每一次拨弦,每一次极深的低频下潜,似乎都要挑动一次脆弱的神经,正是这种虚无变成了真实。而这一切由于“第3通道”的出现而变得更加完美,它可以是优雅的歌者,也可以是疯狂的死亡金属,更可以是金碧辉煌的维也纳,它有无限种可能!
如果一定要形容,那就是:我们因厌倦了固定的风格而衰弱的心脏将会被重新起搏!喜悦尽在《Beat audio TT-X》带来的新音界。 "
translate:
professional comment: Only it has the ability to create your very own pinnacle, extremely vast, very deep and stretching afar sound stage, competent resolving ability allowing you to hear what is wonderful [Note: 吐气如兰 literally means the wonderful scent from a beautiful lady's breath], clear and lush mids, every strum, every sinking of the extremely deep bass, appears to provoke the weak vulnerable nerves, except that virtual has exactly turned into reality.and all this stemming from the appearance of "3x channels" evolving into more complete, it could be a very graceful singer, or can be from wild dead metal , or even grand vienna, it has limitless possiblities!
if there is a need to describe, it can only be: because we hate a fix sound style and this will revive our failing hearts. endless happiness from the new world brought through Beat audio TT-X.
end translation
geez, i will never do translation again, lol. don't think i do a good job.
more detail explanation(chinese) and more clear pics
i still dont understand the technical part regarding the 3 pin....=X basically its gonna need more "juice" to drive the 12 driver version i guess??
