littlemart
APPJ - Tube Headphone Amplifier & Others
APPJ PA1502A – Mini Class A Headphone Amplifier
Class-A single-end triode,100% tube amplification.Designed for resolution of fine musical details, expansive sound stage presentation, and lush tonal quality.
Full aluminum enclosure/chassis
Tubes: 1PC 6N4 – (Changeable to 12AX7; ECC83; ECC803)
2PCS 6P6P – (Changeable to 6V6)
  • Input: RCA Jacks
  • Output: 6.3mm Jacks
  • Output Impedance: 8 to 600 (Japan Z11-EI48*24 Output Transformers)
Selling at $315
Currently available in Black / Silver (Note: the standard package does not come with any power cord)
APPJ HPA Headphone Amplifier Adapter - New Arrival
Convert your speaker tube amp to a headphone tube amp. Direct solution instead of getting another tube headphone amp.
This matching is widely used, can be used in 6F3 EL84 6V6 6P3 EL34 KT66 KT88 2A3 300B or the equivalent power of the single ended, combined into a headphone amplifier, strong drive ability good special effects, can drive HD800 and other high-end headphones.
Parameters:
Input: 4.0mm Banana Jacks
Output:High/low-impedance headphones,3.5mm and 6.35mm stereo headphones
Support:8ohms-600ohms all headsets
Processing power of 8W +8 W
Support: 6F3 EL84 6V6 6P3 EL34 KT66 KT88 2A3 300BGewith the same power single-ended tube amp
Selling at $110
Come in Black/Silver
Edited by littlemart
