Step 3: Insert the OPA2134 X 2. S$4.62 from Farnell code 791039.
If you don't like OPA2134, you can choose other dual opamp IC.
Now you have a choice to use socket or not. Just for-your-info, non-socket opamp have better electrical performance than socket one. The problem with direct solder the opamp on the PCB is the user will not have the fun of opamp rolling, pointed out by another DIYer firefox. Thanks.
If you are new to soldering, it is highly advisable to use socket. Too much heat on the IC will kill it.
Other recommend opamp:
AD8620 (need adaptor)
OP270
Step 4: Insert R9 and R10.
These resistor are use to set the virtual ground voltage. It also let the capacitor discharge when the amp is not using. Both of them have the value of 10k.
Step 5: Input coupling cap C1 and C2.
I use 2 X 1 uF film polyester cap. This cap is use to block all DC supply in the signal. Overall my output DC offset is always less than 5mV, most of the measurement are 2mV. You can short it if you find that your signal has no DC at all. Normally a good CDP will have near to zero DC.
Step 6: Power coupling cap C3, C4 and C5.
I use 3 x 1uF film polyester. You can choose to use 100nF ceramic cap (yellow-brown color one).
Step 7:
Insert the electrolitic cap, the one I used is Panasonic FC. 1000uF, 6.3V, 10mm Dia and 12.5mm length.
If you decide to use +-12V supply, change the cap to 16V. Make sure the dimension remains or else you can't fit into the hammond casing.
Ensure you put them in the correct polarity.
Step 8:
Insert R11 current limiting resistor for the LED. Omit if you don't intend to have any LED. Try to use 1/2w carbon resistor. There is no polarity indication on the PCB. The top is anode (+) and the bottom is catode (-). The approximate formula is:
Iled = 5mA
Vled = 3V
9V = 3V + (R X 5mA)
R = 6V / 5mA
= 1200
Note that it is base on 9V supply and you wanted to feed the LED 5mA of current.
I would suggest to set the current lower to 2mA to save power, use a 3kohm resistor.
Step 9:
Insert the 2 female 1/8 stereo jack. Attach a male stereo pin picture. As you see the first portion of the pin is for left channel, follow by right and ground.
To test which is which on the female stereo jack, what I do is I wear a lousy earphone. Use a multimeter and select to resistance mode and test the few pins to ground. I will hear pop sound to confirm the channel.
Edited by jasonhanjk, 05 September 2006 - 09:03 PM.
