Stereo_Electronics
Maverick Audio Tube DAC/headphone amp
Maverick Tube Magic Upsampling DAC lets you “upgrade” the music listening experience, for any type audio setup, from computer-based systems, to network music devices, game consoles, or standard CD/DVD/Blu-Ray players. Just plug it into your existed setup and enjoy the superior high end sound quality.
Upsampling your digital music
From 16bit to 24bit, from 44.1 kHz to 96 kHz, Tube Magic’s professional-level Audio DAC produces an extremely accurate and distortion-free digital to analog conversion. Your digital music files have never sounded this good before.
Carefully designed analog processing circuit
Without a good analog stage, even the best quality digital music will sound dry and lifeless. After all, music will only be played in analog format via amplifiers, speakers and headphones. We spent a great deal of time to enhance the analog circuit to make sure the analog signal will sound natural, transparent and in great detail.
“Tube Magic” vacuum tube pre-amp outputs stage
Besides the normal RCA outputs, Tube Magic comes with a vacuum tube pre-amp outputs stage. Powered by a vintage 5670 vacuum tube (manufactured back to 1970’s!), it adds a lot warmth and smoothness to the music, especially to Vocal and Jazz. Furthermore, you can use this DAC as a full functional tube pre-amp, adding the “tube magic” to the two analog and three digital inputs.
Wait, it is also a damn good Headphone Amplifier!
With up to 600 ohm impedance and 1000mW power output, this DAC has enough horse power to drive any headphone on the planet.
High-end linear power supply
R-core transformer, super-regulated power circuit purifies and enriches the digital to analog conversion bringing extremely pure, natural and detailed music output.
Uncompromised build quality
Brushed aluminum front panel, 100% handmade, audio grade capacitors and resistors. We make sure this baby is a serious audio equipment.
It’s flexible and easy to set-up
Two digital sources – network music devices, media players, games consoles, CD/DVD players etc. can be connected concurrently using S/PDIF (Coaxial) or Toslink (Optical) inputs.
Two analog sources – portable music players, vintage audio equipments, any audio devices without digital outputs can be connected concurrently using the RCA inputs.
Additionally, you can connect the Tube Magic DAC directly to your PC using a USB connection (no drivers needed) and dramatically improve the quality of your digital music.
What’s included:
* Maverick Audio Tube Magic DAC
* User’s quick start guide
* 5-foot gold plated RCA audio cable
* 5-foot Toslink/Optical Cable
* 5-foot gold plated headphone jack to RCA cable
* 1/8″ (3.5mm) to 1/4″ (6.5mm) gold plated headphone jack converter
* USB cable
* AC Power Cord
Audio inputs
* Optical audio input x 1 (Digital)
* Coaxial audio input x 1 (Digital)
* USB connector x 1 (Digital)
* Analog audio inputs x 2 (Analog)
* Optical connector: TOSLINK 660nm
* Coax connector: RCA, 500mVpp into 75 ohms
* Analog connector: RCA, 1000k ohms
* Accepted sample rates: 32khz, 44.1Khz, 48Khz, 88.2Khz, 96Khz
* Accepted audio format: linear PCM, 16, 20 or 24 bits per sample
Audio outputs:
* All RCA connectors are gold-plated
* Volume control is provided for all outputs
* Two dedicated linear power regulators for DAC and line-out stages
* Dedicated linear power regulators for Tube stage
* Analog RCA outputs signal-to-noise ratio: >96dB
* Tube pre-out outputs signal-to-noise ration: >90dB
* Total harmonic distortion: less than 0.001% (RCA outputs), less than 0.1% (Tube pre-out outputs)
* Maximum output power: 1000mW x 2 (32 ohms), 500mW x 2 (300 ohms), 300mW x 2 (600 ohms)
Headphone outputs:
* Standard 1/4″ jack
* Minimum headphone impedance: 16 ohms
* Maximum headphone impedance: 600 ohms
* Headphone output power: 300mW ~ 1000mW
Power:
* R-core Linear 110/220 manual switch
Physical:
* Dimensions: 10″W x 2.1″H x 6.5″D (260mm x 55mm x 167mm)
* Finish: brushed aluminum in black color
