Effective_audio
Upgrade to All Cambridge Audio CD Player/DAC (With Pics!) !
Dear all,
I have done upgrades to ALL Cambrigde Audio Players new and old. Here are Some Samples:
D500 CD Player
CA640CV1 CD Player
CA640CV2 CD Player
CA740C (sample 1) CD Player
CA740C (sample 2) CD Player
CA840C CD Player
DAC Magic
Scope of Upgrade Generally includes:
Essential Package:
Change and UPGRADE of all critical Capacitors / diodes / Op-amps. All critical locations are futher bypassed with capacitors.
Installation of Burson Clock
Installation of separate Customed Wound Transformer for analog power supply Stage.
High End Options:
Replacement of Burson Clock with EA Ultima Low Jitter Clock and dedicated Power Supply.
Change IC Op-amps to Burson Class A discrete Opamps (Best in the world!!)
Replace critical supply regulators with Burson Voltage Regulator / Ultima Low noise Regulators.
Install Bybee Quantum Purifiers to Power Supply and Output Signal.
Do check with us for optimal Upgrades to your Cambridge Audio Gears!!
Other Player Upgrades Information Available Here:
DAC : http://www.xtremeplace.com/yabbse/index.ph...54958#msg554958
Players : http://www.xtremeplace.com/yabbse/index.ph...38260#msg538260
Others : http://www.effectiveaudiomod.com/upgrades_mods_main.shtml
Cheers!
James
tel : nine694 nine704
email : sales@effectiveaudiomod.com
Customers Reviews / Testimonials:
Hi James,
Here is my brief feedback after 1 week of the modification of Cambridge Audio Azur
640C V1.
Prior to the modification, I have quite a few negative comments on the stock player:-
1) Although it is a relatively smooth player, I find that the player is relatively
weak in terms of PRAT. It is difficult to get the feet tapping.
2) There is a tendency for the mid high to high frequency to be hard sounding at
higher listening levels.
3) Soundstage is rather compressed. It is pretty hard to get the spaces for the
individual instruments and vocals.
4) Dynamics are prettly limited too. Overall a forgiving and very smooth sounding
player and at times too boring to listen to.
After the modification with the burson clock and changes to the critical
capacitors/opamp, the following are the improvements:-
1) Generally all aspects of the audio spectrum is improved. My first comment was wow!
2) The smoothness of the player has not changed but PRAT has improved quite a bit
and now on certain pieces of music, the feet taps uncontrollably. I would say it is
close to analog but not there yet.(What would you expect from a budget player?)
3) The hardness to the mid high to high frequency has almost disappear, however on
certain recordings, probably those not so good ones, it still happens at the highest
dynamic point. I suspect it could be my humble electronics/ speakers that may be
causing the problem. Time to upgrade?
4) Soundstage has open up quite a fair bit, there are plenty of spaces between the
instruments now and you could here each of the spaces within the instruments and how
much reverb is being used on the instruments/ vocals. The width, depth and height of
the soundstage has also improved. The vocalist now stands taller and the instruments
are spread wider and deeper in the soundstage.
5) The dynamics has also improved quite a fair bit, when playing a very well
recorded piano piece at high volumes, you could very well hear the big contrast
between the softest and loudest passage. The soundstage didn’t collapse even at the
highest passage.
6) The transparency of the sound has also improved by quite a fair bit, you could
hear more of the inner details in the highs, mids and even the mid lows(my bookshelf
speakers doesn’t go low). Now you can hear more clearly the plucking of the double
bass, the clearing of the saliva on the lips of the singer and also the decay of the
7) The overall musicality of the player has also improved. From a boring player, it
now becomes a player that has the ability to draw you into music and forget about
the hardware.
Overall it is well worth the cost even though it is more than half the player
cost. I would not say it could beat stock player worth a few thousand dollars but
changing from a pretty boring player to a player that has musicality, transparency
and dynamics. I think James had done a good job.
Jon, on his Cambridge Audio 640CV1 CD Player After Modifications.
Received my Effective Audio James modded Cambridge CD740c yesterday. The CDP overall become very clean & smooth, darkness, fullness body, bigger headroom. tip top layering & separation. it doesn't sound warm but neutral. Recommended mod if you have 740c.
Stanley, on his Cambridge Audio 740C CD Player after modifications.
Got my CDP modded by James of http://www.effectiveaudiomod.com/ back this afternoon. It took three days coz he burned it in and tested it before sending it back to me.
The first thing that hit me when I played the CDP was how smooth everything was; the highs, the mids, even the bass...all sounded smooth with no harshness at all; tested the Eagles' "Get Over It" from Hell Freezes Over album, which tend to sound a bit harsh on many system...well, listened to this track a couple of times, and no harshness was detected at all. The second thing that I noticed right away was everything seems to sound bigger. So the verdict: this is certainly a bang-for-the-buck mod from just the initial improvements that I detected
Earnest, on his Cambridge Audio 740C CD Player after modifications.
James. After the mod every aspect of the player has improved. The PRAT is very good now. There is also much more details. The slight hardness of the sound in the original player is now gone. Thank you very much!
Richard’s feedback on his upgrade Cambridge Audio C640 V2
Other Customer Reviews and Testimonials:
http://effectiveaudiomod.com/Mod_Audio_Test6.htm
http://www.effectiveaudiomod.com/mod_test1.shtml
Cheers!!
James
Edited by Effective_audio
