Stereo_Electronics 0 Report post Posted October 24, 2010 SHURE SE 315 Specification: Speaker Type - Single High-Definition MicroDriver + Tuned BassPort Sensitivity - (1kHz) 116 dB SPL/mW Impedance - (1kHz) 27 Ω Noise Attenuation -Up to 37 dB Frequency Range - 22Hz – 18.5kHz Input Connector - Gold-plated 3.5 mm (1/8”) Cable - 64” Detachable (at ear) with wireform fit Color - Available in Clear or Black Sound Isolating Design Comfortable sound isolating sleeves block up to 37 dB of ambient noise. Sound isolation technology prevents outside noise from interfering with your listening experience, whether on-stage or on-the-go. Shure Sound Isolating Earphones require a proper fit to achieve the best sound. Unmatched Personalization and Comfort Ergonomic, Professional Design -Lightweight, low-profile shape with optimized nozzle angle is designed to rest comfortably in the ear. -Over-the-ear configuration keeps cables out of the way. Detachable Cable with Wireform Fit -Durable Kevlar® reinforced cable allows easy replacement or customization. -Formable wire ensures secure placement, and over the ear configuration keeps cables out of the way. -Gold plated MMCX Connector has a lock-snap mechanism allowing 360 degree rotation for comfortable fit. Premium Fit Kit Includes -Sound Isolating Sleeves The role of the included sound isolating sleeves is twofold: blocking ambient noise and ensuring a comfortable customized fit. Because every ear is different, the Fit Kit includes three sizes (S, M, L) of the flex and black foam sleeves as well as 1 pair of triple flange and 1 pair of universal fit yellow foam sleeves. Experiment with the size and style that creates the best fit for you-a good seal is key to optimizing sound isolation and bass response as well as maximizing comfort during extended wear. -Carrying Case A soft-zip, compact carrying case is included to provide a convenient, tangle-free solution to store and travel with your earphones. Overview Evolved from personal monitor technology that's been road-tested by pro musicians, the SE315 delivers full range sound for personal listening or professional monitoring. High-Definition MicroDrivers deliver full range sound while the Tuned BassPort optimizes low-end performance utilizing a vented driver. Audition units available at Causeway Point and Plaza Singapura! Share this post Link to post Share on other sites
