Stereo_Electronics 0 Report post Posted March 27, 2011 Shure SE 215 Dynamic MicroDriver Featuring Dynamic MicroDriver, the SE215 delivers detailed sound with enhanced bass. A detachable cable with formable wire enables easy replacement and a secure, comfortable fit on-stage or on-the-go. Sound Isolating sleeves in multiple sizes provide up to 37 dB of isolation and a customized fit. Available in translucent black or clear color choice. Product Overview: • Detailed Sound with Enhanced Bass • Sound Isolating Design • Speaker Type: Single Dynamic MicroDriver • Included Fit Kit • Available in Clear or Translucent Black Evolved from personal monitor technology that's been road-tested by pro musicians, the SE215 delivers detailed sound for personal listening or professional monitoring. Dynamic MicroDrivers deliver detailed sound with enhanced bass. Sound Isolating Design Comfortable sound isolating sleeves block up to 37 dB of ambient noise. Sound isolation technology prevents outside noise from interfering with your listening experience, whether on-stage or on-the-go. Shure Sound Isolating Earphones require a proper fit to achieve the best sound. Unmatched Personalization and Comfort Ergonomic, Professional Design * Lightweight, low-profile shape with optimized nozzle angle is designed to rest comfortably in the ear. * Over-the-ear configuration keeps cables out of the way. Detachable Cable with Wireform Fit * Durable Kevlar® reinforced cable allows easy replacement or customization. * Formable wire ensures secure placement, and over-the-ear configuration keeps cables out of the way. * Gold plated MMCX Connector has a lock-snap mechanism allowing 360-degree rotation for comfortable fit. Fit Kit Includes * Sound Isolating Sleeves The role of the included sound isolating sleeves is twofold: blocking ambient noise and ensuring a comfortable customized fit. Because every ear is different, the Fit Kit includes three sizes (S, M, L) of the flex and black foam sleeves. Experiment with the size and style that creates the best fit for you. A good seal is key to optimizing sound isolation and bass response as well as maximizing comfort during extended wear. * Carrying Case A soft-zip, compact carrying case is included to provide a convenient, tangle-free solution to store and travel with your earphones.Technical specifications:Speaker Type Single Dynamic MicroDriverSensitivity (1kHz) 107 dB SPL/mWImpedance (1kHz) 20 ΩNoise Attenuation Up to 37 dBFrequency Range 22Hz – 17.5kHzInput Connector Gold-plated 3.5 mm (1/8”)Cable 64” Detachable (at ear) with wireform fitColor Available in Clear or Translucent Black Share this post Link to post Share on other sites
