Stereo_Electronics 0 Report post Posted October 6, 2011 DUNU HEPHAES Product Feature: Loaded with high grade full frequency unit, DN-16 can provide you deep, full bass, and great momentum (Patent POWER BASS SYSTEM). Along with crisp and crustal mid and treble, DN-16 also presents you excellent sound quality and the best recognition. The earphone is designed with highly covered and sound learking proff which can block the outer noises and only preserves the sound you desire. With broad dynamic frequency ULOTRA driver unit, it makes the sound quality even perfect. Highly airtight stereo earplug earphone can produce broad frequency response and has outstanding balance between highs and lows. Therefore it is able to reproduce the origin high qulaity sound. Multilayer-membrance design hlpes reducing the excess vibration that may cause distortion to achieve first-class quality. Titanium body part is manufactured by metal forging with the mirror finished solid outer skin. We reduce the space between the minor components which avoids the air from leaking, and prevent unncessary vibrations. Thus it can ensure you the fluent bass response and clear middle frequency. Specification: Frequency Response: 10Hz ~ 20kHz Sound Pressure Level: 105+-2dB Impedance: 16ohms Noise Attenuation: 26dB Plug Size: 3.5mm plug Cord Length: 1.2m Weight: 22g Share this post Link to post Share on other sites
