Stereo_Electronics 0 Report post Posted April 4, 2012 iBasso DX100 24Bit/192KHz Reference Digital Audio Player The highly attractive DX100 uses a high-end ES9018 Sabre DAC chip. It also supports bit-for-bit up to 24bit/192KHz high-resolution music files in many lossless format--including ALAC. Apple users no longer have to be binded! Last but not least, it also has a digital output via coaxial and optical. It comes with a massive 64gb on board flash memory and MicroSD expansion up to 32gb.Main Features: - Android2.3 OS With Custom Audio Player Software - Support up to 24Bit/192kHz Bit for Bit Decoding - ES9018 32Bit DAC Chip - Built-in +/-8.5V Headphone AMP - 3.75" Capacitive Touch Screen - Up to 24Bit/192 Optical/Mini Coaxial Output - 3.5mm Headphone Output, 6.3mm Headphone Output, and Line Out - 256-Steps Digital Volume Control - 64G Onboard Flash - Support up to 32G External MicroSD - 3-Setting Gain Switch - SRC Function - Slow Roll-off/ Sharp Roll-off Digital Filter - Support Wifi, Bluetooth - Solid Case Made of Magnesium Alloy and Aluminum Alloy - Audio Formats Supported: APE, FLAC, WAV, WMA, AAC, ALAC, OGG, MP3 - Come With Micro USB Cable, Coaxial Cable, and AC AdapterSpecification:Power Source:Built-in 2000mAh 8.4V Li-polymer Battery pack or external power supply Frequency Response: 20Hz-20KHz +0.1/-0.25dB Signal to Noise Ratio:-116dB Crosstalk: 1KHz0dB > -100dB, 20KHz odB = -82dB THD+N: 0.002% IMD: 0.0034% Gain and Output Power: 0dB=2V rms (125mW/32ohm) +3dB = 2.8V rms (245mW/32ohm) +8.5dB = 5.0V rms (83mW/300ohm) Battery Life: 72Hours (stand-by) or 7Hours (play music) Battery Charge Time: 4Hours External Power supply: 12V DC Recommended Headphone Impedance: 8~600Ω Dimension: 2.83W x 4.65L x 0.93H (inch) 71.8W x 118L x 27.5H (mm) Weight: 265g or 9.3ozAvailable now at both PS and ION Share this post Link to post Share on other sites
