voxel 0 Report post Posted June 11, 2004 Hi, just received my k1000 yesterday. Before getting a dedicated amp, i need to use it on my current tube amp for hd600. Does anyone know where i can get a converter from its XLR to normal 1/4'' Jack, or I have to diy? Thanks you! btw, I heard that some power amps do not accept the 4-pin connector comes with the k1000, does it mean that I also need to diy a converter with real speaker connection? Really dun know anything about pwr amps Regards, voxel Share this post Link to post Share on other sites
lekguan 0 Report post Posted June 11, 2004 It should be able to be bought but would be cheaper if DIYed http://www.moon-audio.com/ under 'Headphones & Headphone Cables' Wonder if they sell just the converter. you can email them. Share this post Link to post Share on other sites
voxel 0 Report post Posted June 11, 2004 thank you lekquan, they take all kinds of hd600/580 cables, some of them are more expensive than k1000 wonder if there are shops selling these converters in SLS... Share this post Link to post Share on other sites
fuwen 0 Report post Posted June 11, 2004 (edited) You can also use the cable provided by AKG to connect your K1000 directly to the speaker binding posts of a integrated amp or a power amp. I do not think any body in Singapore sell headphone jack adaptor for K1000. The K1000 uses a 4-pin XLR connector. You can get in SLS to DIY for yourself. 4 pins because they are positive and negative for left and right channels. Over the headphone jack, you need to solder the left positive and right positive to the respective tip and ring and solder both the left and right negative together to the sleeve of the headphone jack. Of course to do this u need a total of 4 wires. There are some headphone amp out there in the market that accept the 4-pin XLR from K1000 but I have no information on those. Enjoy your K1000. They are really special! Edited June 11, 2004 by fuwen Share this post Link to post Share on other sites
fuwen 0 Report post Posted June 11, 2004 BTW, you need to run in the K1000 for at least 300 to 500 hours using normal music. Share this post Link to post Share on other sites
voxel 0 Report post Posted June 11, 2004 thanks fuwen for the advice. this is my third akg, i think it'll be the last one will go sls next weekend for them~~~. BTW, how's the sound of k1000 from ur ha-2? i'm concerning mainly on the bass. thanks! Share this post Link to post Share on other sites
fuwen 0 Report post Posted June 11, 2004 Depending on the source. If u are using CDP direct or through the tape out of a preamp then for me the HA-2 volumn is at about 80% position. I am a person who do not like heavy bass and most of the time listening to classical music so bass is not a problem to me. Anyway, to me the bass of K1000 is adequate and accurate. The ear speakers of K1000 is adjusable so if u tilt them towards your ear then you will get more bass. This may not be your last AKG, depends whether they are comming out a AKG K2000 or ....... Share this post Link to post Share on other sites
fuwen 0 Report post Posted June 11, 2004 WTW, I dun think many people in SLS selling the 4-pin XLR. I got mine from the shop Coastal Electronics, few shop away from Hungs Brothers, a shop selling lots of funny connectors and switches. I got my Neutrik 4-pin XLR for $5.70 and Neutrik 1/4" TRS headphone plug for $5. Share this post Link to post Share on other sites
voxel 0 Report post Posted June 12, 2004 really appreciate ur infomation I have been using 240DF for nearly two years, and quite satisfied with it for strings & vocals. Actually I'm expecting the similar amount of bass as K501 which is just enough for piano & cello works. (240 is reluctantly enough) Share this post Link to post Share on other sites
