Guest drumma
cMOY question! pls help me!!
Guest drumma
the wires underneath the perfboard are actually those wires in a reel right? like u buy a reel of silver wires.. is it those?
Guest drumma
Drumma,
check this out: kicking.gif
Dual Opamp
Singale Opamp
For 1st timer, i would recommend to work with Single Opamp. the reason is the soldering points are not so concentrated at one region (around the opamp).
I would not recommend copper strips board, unless you have a hand drill to cut the copper path. (i have hard time to work with it yucky.gif )
Pls buy high quality parts for your amp, it's easier to work with.
okies, for the HDP, i think i know how the circuit is being connected but i still dun understand a few things.. maybe u can explain to me? the L-out and and R-out means go where? and what is the 1m?
thanks
According to the pic, the red colour lines are bare wires and pink ones are insulated wire.
Edited by huangyong
Guest drumma
According to the pic, the red colour lines are reel wires and pink ones are insulated wire.
hmm, so what's the diff btw the both of them?
The insulated wires are needed as flying wire. The reason: when bare wires touch each other, they will short the circuit, while the insulated wires won't.
Guest drumma
hmm.. ok.. regarding the gain, is there any recommended gain certain opamps or high impedance and low impedance headphones?
Drumma,
thanks
logically L-out, R-out, goes to headphoe jack.
1m?? If it's the 1M, then it's the input impedance. 1 megaohms
Guest drumma
so what does the input impedance do? is there a guideline for it to be at certain value?
it will function as a High-Pass Filter, which means it will cut off the low frequency.
The formula is: 1 / 2*Pie*R2*C1 = cut off frequency.
Gain = 1 + R4/R3
Edited by huangyong
Young man, seems like you haven't read my explanation in the DIY session:
http://www.sgheadphones.net/index.php?showtopic=2718&st=30
You can use gain 6.6 for low Z headphone, use the combination of 5.6k and 1k resistor. For input, you can use 100k pot and 1M resistor (R2).
Edited by bpribadi
Drumma,
I think you should start afresh with this thread. Forget what's input impedance, what's high pass filter, what insulated wire ..etc at the moment. concentrate what you need to built the amp first.
Physically all those red blue line can use be the same wire. Don't get into cable selection until you have progress further. Resistors/ caps can get from Sim lim tower. Forget about audio grade one first.
oh my god, is this a different design?
this is the original design by Chu Moy.
the HDP is design by digi01.
Guest drumma
no, i'm not talking bout grade A cables or selection of cables. i'm just wondering what is used to connect in between the resistors and everything in there.
i hope u guys hope where i'm coming from. i'm not someone who understands what the pictures really really meant. and i can't find any site which teaches me how to read those? pm me if u have any links?
thanks for all the patience..
