Username
EMU 0404
it uses 1/4 inch mono jack.
In that case if i want to connect directly to headphones i will need a dual mono 1/4" male to stereo mini female. Where can i get that?
And if i connect to a amp then i will need 2x 1/4" mono to RCA right?
Yaufei, the 0404 outputs at line level only, no way you can connect your headphones without amping them.
If you go to most hardware shops, they do sell mono 1/4" to RCA adapter. I got mine at 2 dollars each (IIRC)
